Offroad & 4x4
Rear Shackel Problem
Old Sep 29, 2010 | 07:10 PM
  #106
Ronin4x4's Avatar
Ronin4x4
Originally Posted by scatgo
I wouldn't say useless wider would be more stable. Less likely to roll over. Right?
Yes wider is more stable but if the rims are way offset it is hard on the balljoints. Also harder fitting thru trails but that might not be an issue if the truck isnt used for that.
Old Mar 20, 2011 | 10:58 AM
  #107
scatgo's Avatar
scatgo
Originally Posted by hav24wheel
D50 hubs should work to swap it over to a srw
Wrong
Originally Posted by 82F100SWB
Go to the JY, find 4x4 F250, preferably ex cab, acquire hubs from D50 TTB.
Install on your D60... problem solved.
Wrong
Originally Posted by oreocreaming
D50 came on every x-cab and crew cab F250 from the early 80's til 97. Regular cabs are D44's. And yes, the D50 is 8 lug
Wrong
D50 and 60 hubs are the same part, no difference at all.
Wrong
Originally Posted by fishmanndotcom
yup, did it to my 85 f250. i bought a dually front end an swapped hubs around. it was a direct fit. same bearings and all. from the knuckles out they are identical.
-cutts-
Wrong. Well maybe. This is the answer I got to a email about some hubs for sale on flea bay.....they will work from 86-97 but the 95-97 are different just let me know the year of the truck you need them for if you purchase include a message and thats what i will send you
I looked up the BOM number on my front axle and it comes up a 1996.5 to 1997. Anyone know WTF is the difference is between the earlier hubs and the 97 hubs?
Old Mar 20, 2011 | 11:36 AM
  #108
oreocreaming's Avatar
oreocreaming
how am I wrong kiddo? Had about a dozen of these trucks tat prove me right
Old Mar 20, 2011 | 11:50 AM
  #109
scatgo's Avatar
scatgo
Were any of those trucks a 97 that you tried to put a 1980 D60 hub on?
Old Mar 20, 2011 | 11:59 AM
  #110
oreocreaming
read the quote you said "wrong" do. Did D60 ever show up in that quote? No
Old Mar 20, 2011 | 12:07 PM
  #111
scatgo's Avatar
scatgo
Read all the quotes and I dont know how many posts before that but from all that info I got D60=D50..........
Old Mar 20, 2011 | 12:13 PM
  #112
scatgo's Avatar
scatgo
But I am getting info that the 97 is different. Would like to know what the diff is...........
Old Mar 20, 2011 | 12:17 PM
  #113
scatgo's Avatar
scatgo
It is the 97 that is in question here..
Old Mar 20, 2011 | 01:19 PM
  #114
oreocreaming
who says they are different enough not to fit? Again, my post is correct. It could be as simple as a change in the abs sensor. Doesn't mean it won't swap between other years. Do a little questioning before you challenge peoples posts
Old Mar 20, 2011 | 02:12 PM
  #115
scatgo's Avatar
scatgo
I did say maybe. And the questioning is what I am doing now. So again anybody know what the difference is with the 97 hubs?
Old Mar 20, 2011 | 03:38 PM
  #116
crazyredneckanyhow's Avatar
crazyredneckanyhow
D60 and d50 hubs are the same. No question about it. Hell you can use the spindles off of a d50 on a d60 also. My 79 d60 has d50 hubs on it because i had them and wanted to use the bigger 9/16 wheel studs.
Old Mar 20, 2011 | 05:54 PM
  #117
tjc transport's Avatar
tjc transport
i ain't rite
the only difference i can think of that the 97 would be different is if it is a late production 97 F350 with the 8X170MM metric bolt pattern.
Old Mar 20, 2011 | 10:26 PM
  #118
captain p4's Avatar
captain p4
ABS differences like mentioned before was my first thought.
Are you sure about that Tom? I thought metric started with stupid duty...
Though I think I've seen you say this and challenged you on it before, I can't remember.
Old Mar 20, 2011 | 10:35 PM
  #119
scatgo's Avatar
scatgo
I have been looking into this for days metric started in 2000. In 97 they use a larger diameter rotor. Same hub bigger rotor. And what is up with this ABS ****. I thought the abs thing was on the back axle. You do know we are talking about the fronts right?
Old Mar 20, 2011 | 10:41 PM
  #120
captain p4's Avatar
captain p4
I'm aware. They started putting ABS on the fronts at some point, go research and find out when.
