Offroad & 4x4
Rear Shackel Problem
Old Sep 22, 2010 | 07:07 AM
  #76
fishmanndotcom's Avatar
fishmanndotcom
Originally Posted by hav24wheel
I bet them front tires stick way out!
Originally Posted by scatgo
Yea way out.......
Idk, But you*should* have around 7 inches of backspacing on the front wheels to make them sit the same as the rears. I think........... I could be remembering wrong.
lol i can beat that! dammit, sucks this pic isnt any better. this is when i swapped in a dually front under my white truck
-cutts-
Old Sep 22, 2010 | 08:18 AM
  #77
hav24wheel's Avatar
hav24wheel
O I know how they sit, I have a dually D60 under the front of my wheeler, But my wheels have 7 inchs of backspace
Old Sep 22, 2010 | 10:13 AM
  #78
oreocreaming's Avatar
oreocreaming
That rear axle is too far forward too......
i know, i think it looks like crap. im not done, doing the rear shackle flip kit today, ditching the blocks and either going to move the leafs back OR i think ill end up getting the bushwacker cut out flares to match the front. in that pic, shes under heavy construction. i just finished the shackle reversal kit in that picture.
Old Sep 22, 2010 | 03:05 PM
  #79
oreocreaming
the wheels are for now. Aluminum is easier, faster and heaper then the double beadlocks I'm getting next. 20x10 isn't exactly an off the shelve steel wheel
Old Sep 22, 2010 | 04:14 PM
  #80
alpha/omega's Avatar
alpha/omega
Stazworks might disagree with you.
Old Sep 22, 2010 | 06:10 PM
  #81
oreocreaming
that's who I'm getting them through. 380 a wheel. Their double beadlocks.
Old Sep 22, 2010 | 06:31 PM
  #82
quadzjr's Avatar
quadzjr
just another Rockwell looser
which model did you get?
Old Sep 22, 2010 | 06:41 PM
  #83
oreocreaming
havent ordered em yet. gotta get a ton more before i order them. finishing the shackle reversal kit, half done with the rear shackle flip kit, building ladder bars, extreme drop pitman arm has gotta go on and 5.38 gears front and rear. oh, and getting it painted too. this is the worst paint ive ever seen, and its flaking off with the factory blue under it.
Old Sep 22, 2010 | 07:19 PM
  #84
scatgo's Avatar
scatgo
What kind of tire pressure do you run with big tire like we have? I have Parnelli Jone Dirt Grips 38X15.50R17. I do have a heavy diesel engine . It says 65 pounds with x amount of weight but I guess that would be with a load.
Old Sep 22, 2010 | 09:15 PM
  #85
oreocreaming
with my 37x13.5x18 nitto mud grapplers I ran 50psi and she rode alright, a little rough. With my 42x15x16.5 the max pressure was 30psi. She ran smooth with them. Even when I threw a block of weights, I never even noticed. These 46x15x20 I'm stayin at 30 unless I get a heavy tongue load, then no more then 50
Old Sep 23, 2010 | 12:28 AM
  #86
fishmanndotcom
have you tried the chalk test? that should give you a good idea of where you need to be on pressure. basically you draw a chalk line across the tread face, drive a short distance straight ahead on a smooth surface and then observe the chalk line. You are looking for it to be evenly worn off the tread.
-cutts-
Old Sep 23, 2010 | 05:05 AM
  #87
kjett's Avatar
kjett
I do the water test. Similar to the chalk deal but only takes a few feet. Basically on a flat concrete floor, pour a little water in front of the tires then roll across the water and a little farther. If you can see the whole tread pattern in water on the floor then you are good. Mine are different front to rear due to the empty bed and heavy diesel.
Old Sep 23, 2010 | 10:59 AM
  #88
scatgo's Avatar
scatgo
-cutts-
Ok, thanks. Sounds like you guys got the best ways to get it right.
Old Sep 23, 2010 | 11:01 AM
  #89
scatgo's Avatar
scatgo
-cutts-
I like that bumper!
Old Sep 24, 2010 | 06:37 AM
  #90
fishmanndotcom
I like that bumper!
lol thanks man, that was high school days when free stuff was a must. dont remember where i found the I beam but it sure held up to some abuse! i miss that dam truck RIP "the white truck"
-cutts-
