Go to the JY, find 4x4 F250, preferably ex cab, acquire hubs from D50 TTB.
Install on your D60... problem solved.
That is the plan when the time come but I am somewhat new to this so I have to ask. Are the d50 hus as strong as the 60's? It is the 60 solid axle that is stronger and the hubs are the same? The calipers and rotors I have will work with the d50 hubs? D50 has 8 lugs?
D50 and 60 hubs are the same part, no difference at all.
yup, did it to my 85 f250. i bought a dually front end an swapped hubs around. it was a direct fit. same bearings and all. from the knuckles out they are identical.
