HID lights
Old Mar 13, 2012 | 08:37 AM
  #106
Biggziff's Avatar
Biggziff
Originally Posted by RAPR
I know this is a REALLY old thread, but I didn't really see the point of starting a new one since this thread is directly related to the topic.
I just install a set of DDMTuning HID lights, 55W H13 Hi/Lo 6000K Slim Ballast, and they look great! I did have one concern with the kit however. When flipping on the Hi beams, I don't notice any difference what-so-ever. I did check the bulbs, and it does have the spring/like retracting base on them. Did anyone else see a difference between Hi and Lo beam with this kit?
I will try firing up the bulbs later today and have a friend switch the truck from Lo to Hi beam, so I can visually verify that the bulb does in fact retract properly. I hope I don't go blind in the process.
PS-I ordered the additional wiring harness for my kit, but during installation I didn't really see where it was needed...so I just used the supplied Relay Harness.
I tried several kits including DDM....you have to realize that all these kits are just rebranded stuff made by one of a few manufacturers. I too saw little to no difference with high beams on. I was very disappointed with the light pattern with all the kits. This is due to the design of our housings, not the kits themselves. There is just too much scatter without a focusing lens so the HID stuff just doesn't perform without the lens in place. I find the oncoming cars with HID kits installed to be very noticeable and very annoying as compared to standard lights or proper HID lights which is another reason I pulled mine out.
I can drive around all the time with my high beams on and not get flashed, but it doesn't mean it isn't bothering others on the road. It won't be long before you can't legally install these kits in the US. The government is working hard to make it happen. I used to disagree, but not any more.
Old Mar 13, 2012 | 01:00 PM
  #107
PrinceValium's Avatar
PrinceValium
Originally Posted by lakewood
Dont touch the bulbs with your hands, the oils on your hands will shorten their lives. other than that if you get a simple play n plug kit, its a very easy install, hardest part is taking the whole head light out.
X2..I usually wear latex gloves when putting them in because sometimes when installing them it can be difficult to put bulbs in and not accidentally touch the lens.
Old Mar 14, 2012 | 08:19 AM
  #108
RAPR's Avatar
RAPR
Well I checked the bulbs, and they do NOT move one bit when flipping the switch between Hi beams and Lo beams. That would explain why there is no difference between the two. As of right now, my Lo beams are angled so I can see a definitive line where my output lite stops along the ground. That should be good enough for the majority of the driving I do. I'll contact DDM to see what the deal is with their bulbs/relay.
Old Mar 16, 2012 | 09:02 AM
  #109
Ericwlod's Avatar
Ericwlod
RAPR, did you get any clarification from DDM on what the hi low is suppose to do. I installed the 55w hi/low 4500 DDM HID kit on my 2011 and what a huge improvement on low beams. More than worth the costs as long as they are adjusted properly I don't get any flashing lights at me. The high beams on the other hand are useless, they actually put out less light and as noted by others the scatter is large. I have found though that the low beams are so good that I can live without the highs. The install manual was useless as it left off the installation information for the harness that is required. My kit would not work without it for my 2011 6.7. Also the ground wires were too short on the H13 portion of the kit to reach the batteries (2), if I pulled them to reach, the hi/low wires wouldn't reach so I grounded it to the frame. Not sure how long the wiring kit will last up here in the northeast as the salt will definitely take its toll on the uncoated/crimped on wires in the harnessing.The actual jacks are quality waterproofed but the wires on the back side of the jacks are raw.
Old Mar 16, 2012 | 10:47 AM
  #110
RAPR's Avatar
RAPR
My kit didn't even come with a set of instructions. DDM has not sent me a follow up response after my initial diagnostics. Hopefully they will sent me another hi/lo controller. The way the system is suppose to work is when you activate your hi-beams, the hi/lo controller sends an electrical signal to the magnetically motorize base of the bulbs...causing the bulb to retract a short distance. This is suppose to position the Xenon light arc in the same place as the 'Hi' filament would be with a standard H13(9008) bulb. My bulbs do not move when flipping between Lo and Hi.
Old Mar 16, 2012 | 11:51 AM
  #111
EpicCowlick's Avatar
EpicCowlick
One thing to keep in mind with the DDM products is that they are comparatively very inexpensive HID products. I prefer to think of them as the Walmart versions in the HID world. They provide a lot of value for the money but they do not have the top of the line features like repositioning the bulbs on HI/LO.
Let me throw in some new information. I had the 5000 bulbs installed for a year and a half and experienced the same thing as others in regards to very little difference between the HI and LO setting. The light quality was so much better that it was not a problem. Last January my driver side bulb burned out so I ordered some replacement 4500 bulbs. Turned out the driver bulb wasn't burned out, the connector just needed to be re-seated. When I tried HI/LO with the 4500 bulb, it works much better. There is a sharper horizontal cut-off line on LO and when switched to HI it fills the area above the cut-off with tons of light. Go figure. All I did was switch the bulbs only. I did not change anything else. Call me crazy but that's what is happening. Here was my most recent order:
Old Mar 16, 2012 | 12:54 PM
  #112
Ericwlod's Avatar
Ericwlod
Epic, I agree with regards to the cost and quite honestly you can't beat it, replacement stock Sylvania halogen are 55 bucks a pair, I don't know how they sell the entire HID kit shipped to my door for under 100! I would recommend them as a huge improvement over stock.
But back to your comments with regards to high beam, when I switch mine to high the light is much less bright than on low beam, perhaps it the scattered light that is mentioned. The light definitely is spread out much more but is definitely less bright all around.
I also reviewed the bulb very carefully and these DDM Tuning lights are not intended to retract. I have factory HID lights that are road following (i.e. gyroscopes guided) on several of my vehicles and they retract in and out to produce the high beam. These factory units are much more sophisticated and obviously have the focusing lenses and come at a very different price tag.
What I don't understand is when mine are on the hi beams the light output below the "horizontal line" you mention is actually less less than being on the low beams? I still don't mind because the lo beams are so much better but perhaps I have something incorrectly hooked up or bad bulbs?
Old Mar 16, 2012 | 02:29 PM
  #113
RAPR's Avatar
RAPR
Can either of you guys do me a favor? Next time you are around your truck and have a friend with you, can you get your friend to switch your truck's lights from Lo to Hi while you look at your bulb inside the housing? (the base of the bulb so not to go blind) Since your headlights do change 'some what' from Lo to Hi, I wanted to know if your bulb retracted when switched to 'Hi'....as I don't see any change nor do I see any bulb movement.
Old Mar 17, 2012 | 04:48 PM
  #114
Ericwlod's Avatar
Ericwlod
Rapr, I am mistaken mine do move in and out from low beam to high beam. Know I understand why the light output is so different/scattered on hi.
When I switch to hi beam they retract in.
Old Mar 18, 2012 | 04:52 PM
  #115
RAPR's Avatar
RAPR
Thanks for checking that out for me. I heard back from DDM. They are going to ship me a replacement Hi/Lo controller. I hope it is as easy as just disconnecting the controller from the harness, as I really don't want to take the front grill and headlight back off to swap the harness too.
AGrayson84
Dec 18, 2016 07:52 PM
NCMODELA
Feb 23, 2016 01:19 PM
Finally Powerstrokin
Oct 9, 2012 06:51 PM
mblack14
Jun 30, 2012 06:15 PM
Milwaukee,WI
Aug 25, 2009 06:51 AM
