HID lights
Old Sep 20, 2010 | 07:28 AM
  #46
EpicCowlick's Avatar
EpicCowlick
Whoa! $92 for 15 feet? That would actually cost more than the entire HID system for the truck. No need for NASA certified fasteners here...
I just got whatever Home Depot has and I use it for a lot of different things. Probably $4.99 for about 10 feet if I remember right.
Old Sep 20, 2010 | 07:51 AM
  #47
GMUGNIER's Avatar
GMUGNIER
Originally Posted by radzer0
From my personal experence. Do NOT buy oracle brand.
If you want something to last a long time buy a phillips kit. You would prob be looking around $1500 installed or around $1200 for the complete kit.
But you can expect the duribility out of it as a new factory HID system vs a aftermarket cheapo that gives every year or 2.
Still no info on these Phillips kits! I bought the phillips ballast kits for years and lately I guess no one is selling them anymore - Sp RADZER0 any info? or is all just a bunch o hooey?
Old Sep 20, 2010 | 08:25 AM
  #48
HawgGuy's Avatar
HawgGuy
Originally Posted by BTyner41
I see a need for another instructional video Epic.
X2 - that would be terrific.
Old Sep 20, 2010 | 12:08 PM
  #49
RBolton6's Avatar
RBolton6
Epic, still a little confised on what to buy? The kit is $65 and do you also need the relay harness?
Old Sep 20, 2010 | 02:28 PM
  #50
RickSo's Avatar
RickSo
Yeah....you are right about that. We have a 150ft roll here at my work and I just use a few inches for small projects. It is used to replace rivets and bolts in some applications, also solvent oil and gas resistant. So, 6 or 8 inches for a couple of ballasts won't be that bad....about $5.00 my cost. I am going to call on the HID's today and see if they will ship to Canada. Thanks for the info on these lights.
Rick
Old Sep 20, 2010 | 04:26 PM
  #51
EpicCowlick
There are three parts to the order:
  1. Bulbs and ballasts
  2. Hi/Low relay
  3. Wiring harness
Someone mentioned on another thread that they did not need the harness. Maybe DDM Tuning changed something but I definitely did. Good luck with it.
I'm going to adjust my headlights down a little bit because I am getting flashed by oncoming traffic every now and then. The SD allows for some vertical adjustment via a screw behind the headlamp assembly. You ought to take care of that at the same time you're installing the new HID's.
Old Sep 20, 2010 | 04:52 PM
  #52
sdetweil's Avatar
sdetweil
that was me.. the balast kit comes with a wiring harness.. I didn't need the relay wiring kit.
so, I bought the 5000k H13 hi/low blubs, and the low profile balasts
wish I had ordered the 4000k bulbs.. 5000 is a little too blue for me.
here is the ford order page
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
Sam
Old Sep 20, 2010 | 05:28 PM
  #53
RBolton6's Avatar
RBolton6
Thanx all. Just ordered the 55W, 5K kit today. As you suggest, will likely adj down the aim while I'm in there.
Old Sep 20, 2010 | 09:23 PM
  #54
RickSo's Avatar
RickSo
Based on the comments here I think I'll order the 4500K lights/Slim Ballasts/Harness.
Rick
Old Sep 20, 2010 | 09:44 PM
  #55
EpicCowlick
Nice screen capture. Makes it pretty clear.
Old Sep 24, 2010 | 04:00 PM
  #56
cirrus365's Avatar
cirrus365
I got my HIDs in today and will install them this weekend. Has anyone changed any other bulbs out for LED's?
Old Sep 24, 2010 | 04:01 PM
  #57
radzer0's Avatar
radzer0
Im looking for silverstar pictures. Has anybody put these vs the HID install?
Old Sep 24, 2010 | 04:15 PM
  #58
cirrus365's Avatar
cirrus365
I had silverstars in my last truck but the difference between them and factory was minimal. sorry, no pics.
Old Sep 24, 2010 | 04:16 PM
  #59
radzer0's Avatar
radzer0
I would be chaging them more for frontal looks. Not actual road view. The stock setup in the 2011 gives me good enough view.
Old Sep 24, 2010 | 05:22 PM
  #60
cirrus365's Avatar
cirrus365
Trying to figure out the wiring harnesses. I have one that is fused with a relay. A second harness that is fused with a piece that is larger than a relay with 10 wires going in to it (I am assuming this is the hi/low switch). Two ballasts and bulbs. Do I need to connect both harnesses to the battery? and are the grounds floated off the relay harness?
