2011 2.5" Receiver
Old Aug 28, 2011 | 10:40 PM
  #61
Benoit1967's Avatar
Benoit1967
2011 F350 Crew Cab with the 6.7L and the dealer gave me the adapter. Of course, got home and tried to put my hitch and... the pin was too short. A quick trip to Canadian Tire (mini Wal-Mart like but no food, no drugstore, no books... well...different enough I guess) and found a pin that fits nicely and still locks... 17 dollars I think it was.
Old Sep 14, 2011 | 02:04 PM
  #62
2011F-250KR's Avatar
2011F-250KR
I too had an issue with the 2” reducer sleeve not going in at all. ($20 - made by Curt IIRC) I used by belt sander to make it fit. It was not just the radius of the corners as mentioned in previous posts. I ground off the sides a little at a time until it eventually fit with some “percussion persuasion”
My 2” hitch slid right into the reducer sleeve, but seems to have a lot of slop. About an 1/8” inch which equals almost 1/2“ up and down at the ball. So I figured it was just a crappy sleeve with a not very good factory quality control or tolerance.
I asked the dealer about it later, they do not supply the reducer sleeve with the trucks (and yet I have a King Ranch). They also did not have the Ford one in stock at the parts dept.
My question: Is the Receiver supposed to be 2.5” or is it a tad bigger and the Hitch is 2.5? Also does anyone know the tolerance or what is acceptable slop? It seems so random as to what manufacturer brands fit and which ones don’t.
Old Sep 14, 2011 | 02:51 PM
  #63
ETKMS's Avatar
ETKMS
Trust me, I tried so many, including curt, after bringing it to a machine shop, it fit, but was still not correct, the pin hole was to far back, and it made the sleeve sit very far in, I still towed with it like that, but it was to much for what i felt was right. I got the OEM ford one, yes, i too had to pay for it.. But its worth it and fits like a glove..
Old Sep 14, 2011 | 02:52 PM
  #64
Part-Timer's Avatar
Part-Timer
My April '11 build KR and my buddy's February '11 build KR came with the reducer already in the hitch along with the pin.
Brian
Old Sep 14, 2011 | 03:14 PM
  #65
2011F-250KR
Tks for the input. I'll end up getting the Ford sleeve to replace the crappy one. I am still curious as to what the exact dimensions are SUPPOSED to be for a 2.5" receiver/hitch.
By the way, my truck is a Sep '10 build.
Old Sep 14, 2011 | 06:58 PM
  #66
KC8QVO's Avatar
KC8QVO
The 2.5" hitch is a heavier duty hitch, class V or VI (mine shows 14,000lbs on the sticker). The 2" receivers aren't rated nearly that high. You also won't find a 2" drawbar rated for much more than 10k. You need to hit the 2.5" realm to get the higher rating (mostly the heavier duty Weight Distribution drawbars with 2 5/16" *****).
My truck came with the reducer and pin also. I realized that after I drove about 100 miles on my way home with it. I stopped at a gas station and pulled it out so I wouldn't have "someone else" pull it out for me and walk off with it.... I don't leave anything in my receiver. My locks don't work on it as they are 2". I'll need to get a 2.5" one one of these days.
Old Sep 14, 2011 | 07:20 PM
  #67
720Deere's Avatar
720Deere
I wonder how many of the guys that complain about the 2.5" hitch are still carrying around tow ropes rated at 6,000 lbs? I won't lie, I have an adapter sleeve for my 2" ball hitch that rarely gets used, but for anything heavier especially a pintle hitch it is worth the cost to upgrade and match your truck's performance.
One thing to consider in place of the regular hitch pins that never seem long enough is a farm tractor hitch pin. Most of them are rated higher than the pins meant for a receiver hitch and they have a big handle that makes them much more convenient.
I have wondered why Chevy has included a reducer sleeve with their class V hitches for several years and Ford doesn't seem inclined to do it. The answer that I can think of is that if they provide you the adapter they are basically telling you that it is ok to us a drawbar rated for a lower capacity than the receiver and thus opening themselves up for a lawsuit.
Old Sep 14, 2011 | 08:16 PM
  #68
huntindog's Avatar
huntindog
The GMs not only come with the reducer, but the longer pin as well.
I'm rather surprised that Ford would cut a corner like this. Many customers will be upset about such a obvious cost cutting move.
Old Sep 15, 2011 | 02:59 AM
  #69
lexustbs's Avatar
lexustbs
I agree. There is a reason the size has increased .5"
If I was Ford, there is no way I'd sell the "shim."
WolfFox
Jan 7, 2024 03:54 PM
woodsd79
Jul 14, 2020 05:10 PM
Super~Duty
Jan 16, 2017 11:55 PM
montauk1
May 9, 2016 10:24 AM
GCLL
6.7L Power Stroke Diesel
19
Oct 2, 2010 08:10 PM
