Need Steering Wheel Help STAT
Old Jun 23, 2010 | 05:47 PM
bobj49f2's Avatar
bobj49f2
You can remove the cab with the steering column still place but the wheel has to be off. Even though you can take the cab off with the column still installed it's a major PIA. I've done it a few times on parts trucks using a fork lift truck outside so I had a lot of overhead clearance. I also helps to have some one on the ground to maneuver the pedals through the inspection plate. It's a PIA to remove the cab with the steering column removed and still have the pedals installed, I will guarantee the cab floor will get hung up on the pedals. The easiest way to go is remover the steering column and the pedal assembly, I mean the whole pedal assembly not just the pedal pads.
Old Jun 24, 2010 | 08:24 AM
AXracer's Avatar
AXracer
I would assume that if doing a "cab off" that they would also remove the pedal assemblies.
DeanBob
Mar 4, 2013 06:30 PM
davidwin
Jun 4, 2011 01:15 AM
compman25
Aug 27, 2009 11:48 PM
73cntry
Aug 11, 2009 05:52 AM
J_Bowers04
Mar 17, 2008 08:14 PM
