95 F150 steering box
Old 06-03-2011, 04:37 PM
davidwin's Avatar
davidwin
davidwin is offline
I replace the steering box with a used steering box. Wheels are straight, but the steering wheel is off center by about an 1/8 of a circle. When reconnecting the steering column shaft down by the box I need to rotate the steering wheel in order to reattach. It all looked straight at the time but once around the block I saw the problem with the steering wheel being off center. My thinking is pull the pitman arm, center the steering wheel reattach pitman arm. Am I getting in deeper trouble doing this? Or is there another solution I don't see?
Any imput would be helpful.
Old 06-03-2011, 07:44 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
The Pitman arm only fits in one position, because of the geometry of the sector shaft. You should try any corrections at the steering shaft, which is above the steering box.
Old 06-04-2011, 01:15 AM
xxshine's Avatar
xxshine
xxshine is offline
First, the pitman arm can be modified to slip on the sector shaft at any position. Second, adjust the toe. Take and loosen the pair of bolts on each side of the drag link, where it meets the tie rod ends. Mark the current position with a permanent marker and then turn each side the same number of increments. It may help to use a piece of tape measure and bend it along the round rod to get a measure. If you need more help : taleenamersaid@yahoo.com
daverd4
03-16-2015 09:56 PM
olguy317
17
09-11-2014 03:40 PM
flamesoldier
02-11-2013 10:04 PM
vinmanin
1999 to 2016 Super Duty
05-05-2010 05:27 AM
qtrmiler
29
02-08-2003 10:10 PM
Quick Reply: 95 F150 steering box
