Removing steering wheel help
Old Aug 26, 2009 | 11:05 PM
compman25's Avatar
compman25
So just how do I remove the steering wheel in my 78 when the previous owner stripped the threads in the wheel? Is there another type of puller I can use to pull the wheel off?
Old Aug 26, 2009 | 11:13 PM
mikeo0o0o0's Avatar
mikeo0o0o0
What about putting a Helicoil in the stripped threads?
Old Aug 26, 2009 | 11:39 PM
compman25's Avatar
compman25
Was hoping for another way, I don't plan to keep the wheel, just want it off. If I have to I guess I will helicoil it.
Old Aug 27, 2009 | 12:11 AM
75F350's Avatar
75F350
Drill and tap the old holes to the next size and use different bolts for your puller.
Thats the easiest way.
Old Aug 27, 2009 | 03:24 AM
USArmyTaterness's Avatar
USArmyTaterness
Or if you are to lazy to walk over and get the drill bit like me you can do six times the amount of work and wiggle it off my hand. (It's been done and never ever again)
Old Aug 27, 2009 | 03:35 AM
miottimouse's Avatar
miottimouse
i have removed them this way without a puller at the picknpulls crude but it works undo the center nut untill it is to the end of the shaft grab the wheel on both sides pull hard toward you have a freind [that you trust] hit the center nut with a hammer firmly should pop right off done many wheels this way hope this helps regurds joe
Old Aug 27, 2009 | 09:00 PM
compman25's Avatar
compman25
Drilled and tapped, it's off. Thanks
Old Aug 27, 2009 | 11:48 PM
USArmyTaterness
No problem glad everyone could be of a service to you.
dcagnolatti
Jan 14, 2015 10:59 AM
UaVaj
Oct 16, 2014 11:23 PM
Stangfamily
1947 and Older Ford Trucks
Aug 7, 2014 04:12 PM
Piece of Kake
Oct 22, 2009 03:37 PM
