Question/Request for Pics Measurements COE
Old May 12, 2010 | 09:33 AM
texag09's Avatar
texag09
Many of you have seen my Introduction thread for my 1948/49 Ford COE F-5, and I need to thank ya'll for all the great input and advice.
I have one disadvantage I work Overseas/Away from home. Right now I am only 150 miles from the shop so can go every weekend (for now atleast).
For some planning and research purposes does anyone have good pics and measuremetns of the cab mounting subframe structure for these trucks?
Thanks in advance.
Old May 12, 2010 | 10:22 AM
Julies Cool F1's Avatar
Julies Cool F1
Maybe this will help it is for 51 but should be the same (curb weights may be slightly lower on the 48/49):
Name:  F5 Stake Bed Specs -  COE.jpg
Name:  F5 Stake Bed Dimensions 2.jpg
Name:  F5 Side Profiles.jpg
Old May 12, 2010 | 12:19 PM
texag09's Avatar
texag09
Thanks that helps alot but what I am really looking for is the measurements of the undercab moutning locations without having to take off the cab. For frame donor checks.
Old May 12, 2010 | 12:46 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
This probably doesn't give you exactly what you're after either, but here's the subframe diagram from the Chassis Manual. Stu
Old May 12, 2010 | 01:35 PM
texag09's Avatar
texag09
Stu,
That helps alot, now I have an idea and just need the basic footprint dim. if anyone has that or can pull a tape on one. that is off the frame.
What book does that come from? Need to purchase one if I can.
Old May 12, 2010 | 02:10 PM
truckdog62563
It's out of the Chassis Manual. There were several versions. I suspect there were versions from 48 to 51, but the one I find most helpful is dated 1/52. I like it because it includes all parts numbered as they were when the trucks was new. There is also a 1/54 edition and a 1964 reprint edition that covers 48-56. The '64 can be purchased new from any of the prominant parts suppliers. One big drawback to the '64 reprint is the fact that it dropped parts that were NLA, or that had been combined with other parts for wider application. As a general guide, though, it's fine. You can find used copies of each pretty regularly on eBay also. Stu
Old May 12, 2010 | 03:06 PM
48fordcoe's Avatar
48fordcoe
A COE will fit a 48 to 52 F-1 frame with no problem . the sub frame of the coe fits right on but if you can get a P30 step van it wider .
Old May 12, 2010 | 04:01 PM
texag09's Avatar
texag09
Thanks for the help I was thinking 80's or 90's 1 ton truck?
Old Jun 24, 2010 | 12:06 PM
chad79's Avatar
chad79
wheel base
48 ford whats the wheel base on your green truck?Did you shorten the 51 frame?
50COE
Engine Swaps
Nov 8, 2021 04:58 PM
ZFLASH
37
Jan 26, 2017 09:47 PM
hardsand
Testing.....
Oct 18, 2016 04:27 PM
Last Triumph
Oct 5, 2015 01:51 PM
robertr
1947 and Older Ford Trucks
Mar 1, 2002 09:32 PM
