New axle steering wheel 180 deg out
Installed Dana 60 axle off a 96,97 F350 on my 94 F250 getting rid of the TTB50.
Hooked up the steering arm to the pitman and my steering wheel was 180 deg out so my horn buttons were on top of the steering wheel vice the bottom.
I took off the steering arm adjusted it in so I have one thread showing and it helped out a lot. Still the steering wheel isn't quite straight when the wheels are straight. The steering wheel is still a little to the right as you're sitting in the truck.
Any help or suggestions?
The only thing I was going to do is pull the pitman arm move it one tooth to the driver side tire and re hook up the steering arm.
Now it's good to go!!!!!!!!!!!!
jayro88
11-25-2012 01:05 PM
