Remanufactured 300?
JASPER Engines & Transmissions: Remanufactured engine: diesel, marine, import
350 Chevy Crate Engines - 383 Stroker - Ford - Dodge - Remanufactured, Custom and Performance Engines
Rebuilt Engines - Engine Rebuilders - Engine Restoration Services
You are right...there is a bunch of them but that is three that i know of that maybe good. Try shopping around your local area.
Well, now would be a good time to back up to 1983 or older DS2 ignition system and carb and get away from the DFC (Dreaded Feed-back Carb) then you can do away with the computer controller and if you get a head with the AIR ports, just plug them with plugs of the correct thread which you can probably obtain at most any hardware store.
My other motor is gone and I put a 84' motor in the 86' truck just to get it going for $150. I can't check the oil because the dipstick is in the wrong place. I am going to get a 1986 reman without the smog holes. I just need someone to tell me what to get because I also think that something is wrong with the computer (previous owner thought). So I'm wanting to do a full restore on the truck and motor. I got this truck so it would force me to learn about this stuff. I have no experience, but am willing to listen and research. Also, would it be better to do the dsII swap before or after I get the other motor? Do I need a new carb and what year should I get? I think I need a new harness, will this effect the warning light or guages? Thanks for your help.
Make sure that anything you do doesn't conflict with state smog regulations if there are any.
fshoffner
01-22-2000 11:37 PM
