300-390 swap
Old Dec 31, 1969 | 06:00 PM
Guest
Guest
Posts: n/a
300-390 swap
Old May 9, 2002 | 10:27 PM
kford1's Avatar
kford1
300-390 swap
i have a 86 f150 pick-up with a 300 , how hard is it to throw a 67 390 engine into that truck
Old Jun 4, 2017 | 07:59 PM
Jared Skadberg's Avatar
Jared Skadberg
As I understand it the 390 and the 300 have different bolt patterns on the back to the bell housing. The 300 is in the i believe "Y" block family of motors and the 390 is not. would probably take a tranny swap to boot and motor mounts are not going to be compatible. Other motor that would drop ridght in are 302 351 and I think 460, but not 360/390 blocks.
Old Jun 4, 2017 | 08:20 PM
Gary Lewis's Avatar
Gary Lewis
Jared - This thread is 15 years old. Also, the 300 has the small-block bell housing pattern, but you are right that the 302 and 351W would bolt to the tranny. Here are some thoughts about swaps, just FYI: Engine Swaps - ???Gary's Garagemahal.
Old Jun 4, 2017 | 08:42 PM
Jared Skadberg
Right i saw it was that old after i posted lol. Was right up at the top of the forum tho.
Old Jan 29, 2018 | 08:20 PM
HighPlainsRichard's Avatar
HighPlainsRichard
4wd Low
And why on Gods green planet would you ever want to ditch a running 300? It's one of the most dependable, torque monster, motors ever made. I had one in a '72 F100. I miss that truck. And that motor. You could stand on the ground inside the hood and work on it.
Old Jan 29, 2018 | 10:25 PM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
Ive actually swapped a 390 into an 81 F250 before. the crossmember under the oil pan needed to be modified. I learned that AFTER the crossmember ate a hole through the first oil pan.
I did it like 15 years ago, maybe i was the one who made this post, under a username i long ago forgot.... who knows....
