check engine light
Old Jul 1, 2010 | 11:00 AM
  #31
chicagodragon's Avatar
chicagodragon
UPDATE... i replaced the DPFE sensor, cleared the codes and went for a ride. it took almost 7 miles for the check engine light to come back on (last time it was back on in 2 min). the codes are p0153,1151which point to the upstream drivers side 02 sensor. and a p0401 EGR. i do suspect a leaking EGR gasket that i will change when i get home (the weather has been crappy). could that be setting the other codes, or do i need to change the 02 sensor? also, how far is a "drive cycle" ? because i am wondering if the other codes may come back. which were...p0402,p1401 and p1151.
Old Jul 1, 2010 | 07:57 PM
  #32
chicagodragon
update part 2
i just finished replacing the EGR gasket, the old one fell apart. i went ahead and replaced the upstream o2 sensor on the driver side. i am no expert, but an o2 sensor is not supposed to rattle is it? i am going on a test drive and see what happens. what exactly, or how long is a drive cycle?
Old Jul 1, 2010 | 09:26 PM
  #33
chicagodragon
after 12 miles, code p0401, insufficiect egr flow, came back. is the egr valve bad? or the controller?
Old Jul 3, 2010 | 12:12 AM
  #34
chicagodragon
after reading every post on this forum with code p0401 in it, i decided to pull the throttle body and elbow for cleaning. i had no idea that it could get this gunked up.
lalberts
22
Jan 11, 2017 10:16 PM
brentkhack
Sep 27, 2016 01:51 AM
jerelp86
1983 - 2012 Ranger & B-Series
Apr 26, 2015 12:00 PM
Joshzzz
Nov 7, 2014 02:26 PM
lovs2fly
Oct 4, 2006 10:49 PM
