455 code where to start
Old Oct 4, 2006 | 10:07 AM
lovs2fly's Avatar
lovs2fly
I have a 98 explorer XLT with a check engine light. The code is 455. Any ideas where to start? As background I have just had the tranny rebuilt a week before the check engine light came on. Thanks
Old Oct 4, 2006 | 10:21 AM
mediaman67's Avatar
mediaman67
Try replacing your gas cap - it's an evap code... don't think it has anything to do with the tranny - is this P0455? Short of that, it could be a vaccum hose got knocked off when they did the repair...
Old Oct 4, 2006 | 10:49 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
Being this system is OBDII it is required by law to monitor all of it's own emissions. Since a fuel leak technically is an emission (HydroCarbons) the EVAP system was developed to test that.
It pulls vacuum on your fuel tank.. and then measures that vacuum for awhile to make sure it holds. If it does not hold vacuum, it sets a code. This can be caused by.. leaving the gas cap off, bad gas cap, hole in tank or vacuum lines (typically a fuel VAPOR leak.. not so much a liquid leak), or a disconnected or failed EVAP component.
Best I can tell you is buy a new gas cap (not a locking type as those tend to leak) have the code cleared and drive for awhile.. if the code comes back I highly recommend taking it to a professional, as these can be a S.O.A.B. to diagnose.. I've had many I've actually had to use an EVAP APPROVED smoke machine on to find the leak. Also had some intermittant purge valve failures which weren't closing off the system properly prior to the computer running its evap test and 'fooling' it into thinking there was a leak.
Good luck
Leo455
Transit Connect
Jan 20, 2017 09:34 AM
Warren Hart
Sep 30, 2016 06:35 AM
Lgordon003
Jun 19, 2015 04:56 PM
japa11
1983 - 2012 Ranger & B-Series
May 5, 2015 09:17 PM
robjs111
1997 - 2003 F150
Feb 11, 2011 06:49 AM
