2000 window issue
Old Jul 2, 2010 | 06:38 PM
dieself250's Avatar
dieself250
2000 window issue
my drivers window dosent know when to stop. one touch down works fine untill the window is down all the way, and the motor keeps running untill you hit up to stop it. and it will do the same in the upmost position too. any ideas
Old Jul 2, 2010 | 07:22 PM
alloro's Avatar
alloro
To work, the OTD circuit requires the motor to lockup which increases the current draw. When it senses this increase in current, it drops out the relay to cut-off the power to the motor. Since your motor "keeps running", something is slipping and the motor doesn't lockup to increase the current to make the relay cut-off the power. I guess it's possible the motor gear has stripped enough to allow slippage but not enough to keep the motor from operating the window.
Old Jul 3, 2010 | 10:40 AM
dieself250's Avatar
dieself250
it looks like its time to take the door apart and see. thanks for the info
motorcarmike
Jun 11, 2021 10:11 AM
Daviddc114
Jul 6, 2016 10:56 PM
LARIAT 85
Mar 26, 2013 07:38 AM
boggerted
Mar 18, 2010 02:32 PM
a64armt
Jun 1, 2006 07:38 PM
