check engine light
Old Jun 12, 2010 | 10:49 PM
alloro's Avatar
alloro
Originally Posted by chicagodragon
the iac motor was unplugged.
Any idea why?
Pull off the ERG valve and see if the ports underneath it are clogged with carbon build-up.
Old Jun 13, 2010 | 10:02 AM
chicagodragon's Avatar
chicagodragon
The clip is broken. I secured it with a small zip tie. O will Check the egress in a bit
Old Jun 13, 2010 | 11:33 AM
chicagodragon
the EGR was kinda clean, so i cleand it and the port behind it out. broke a bolt in the process, fun fun. but, i did notice a broken hose on this... what is it?
Old Jun 13, 2010 | 11:48 AM
c_hohensee's Avatar
c_hohensee
That is your DPFE sensor. Those hoses go to exhaust tubing for the egr valve. This would certainly account for the egr codes.
Old Jun 13, 2010 | 11:57 AM
chicagodragon
What does DPFE stand for?
Old Jun 13, 2010 | 12:58 PM
c_hohensee's Avatar
c_hohensee
Differential Presure Feedback EGR. This monitors the flow of the EGR system.
Old Jun 13, 2010 | 01:12 PM
chicagodragon
i just went to autozone to get codes pulled again. i am down to one...1401, the dpfr circuit high voltage. what now?
Old Jun 13, 2010 | 01:47 PM
c_hohensee's Avatar
c_hohensee
It is indicating that the voltage range for that sensor is being exceeded. It could be a short to ground or an open cuircut condition within the sensor itself.
Old Jun 13, 2010 | 02:07 PM
chicagodragon
Should I Just change it? Or is There a way to fix it?
Old Jun 13, 2010 | 02:55 PM
c_hohensee's Avatar
c_hohensee
If it is the sensor itself there is no repair. If you cannot find any shorts and do not have access to factory diagnostic manuals and a NGS scanner changing it may be your best bet. If you do have those things, there are a number of tests that can be run to pinpoint the trouble. The most reliable of the replacements has been a Ford replacement part.
Old Jun 13, 2010 | 02:58 PM
chicagodragon
i have the ford part number, but i was looking and couldnt even find one aftermarket. does it go by a different name?
Old Jun 13, 2010 | 03:06 PM
powersmoked's Avatar
powersmoked
rockauto.com ->your vehicle->emissions-> EGR pressure feedback sensor->motorcraft $67
Old Jun 28, 2010 | 04:28 PM
  #28
chicagodragon
due to lack of time, i havent had time to get back on this. question... below is a pic of my EGR pressure sensor and the aftermarket one from rock auto. how do i know where to connect the hoses to? the aftermarket is marked, i dont see anything on the original.
Old Jun 28, 2010 | 05:39 PM
  #29
alloro's Avatar
alloro
Just match their positions from left to right.
Old Jun 29, 2010 | 06:58 AM
  #30
c_hohensee's Avatar
c_hohensee
I think the hoses are 2 different sizes, so matching them up would be the correct way to connect them.
