check engine light
Old Jun 10, 2010 | 11:03 AM
chicagodragon's Avatar
chicagodragon
check engine light
i have a '97 expedition. i think the check engine light is burned out. where on the dash is it? also, i am getting a rough/low idle when the ac is on, where do i start? i just did plugs and wires, cleaned the throttle body. BTW its a 4.6. thanks
Old Jun 10, 2010 | 11:30 AM
bnovak's Avatar
bnovak
wow - your CEL has been on long enough to burn out? Might wanna get that looked at!
I don't remember the exact position, but if you are replacing bulbs, save yourself the frustration and just replace them all (If I remember correctly, there are 6 total)
I spent the hour to replace one backlight, only to have the one on the other side burn out the next week. Round two, I just replaced all the old bulbs.
Old Jun 10, 2010 | 11:43 AM
chicagodragon
i just picked up the truck a couple of months ago. still working out the bugs.
Old Jun 10, 2010 | 09:19 PM
projectSHO89's Avatar
projectSHO89
See my signature for a manual. The owner's manual shows where every bulb is located.
Old Jun 11, 2010 | 09:41 AM
alloro's Avatar
alloro
Shine a flashlight on the instrument cluster and you'll be able to see all of the writing that gets lit up when the bulbs are on. Also, the CEL should light up when you first turn the key on. If it doesn't then it's either burned out like you suspect, or the previous owner removed the bulb in order to sell the truck for more money.
Old Jun 11, 2010 | 10:20 AM
chicagodragon
i am pretty sure it is burned out. the guy i got it from would be to lazy to take it out. besides, the previous owner is my neighbor. sold it to me extra cheap just to get it out of the driveway. any thoughts on the rough idle?
Old Jun 11, 2010 | 11:15 AM
alloro's Avatar
alloro
A rough idle can be from burn valves. But if it's more of a low idle than a rough one, I'd clean or replace the IAC valve (top front of the throttle body). It's supposed to raise the idle to compensate for the added load caused by the compressor. It doesn't sound like that's happening, so it could be gummed up.
Old Jun 11, 2010 | 11:29 AM
chicagodragon
gotcha. i remember those, ive been on diesel for to long. thanks.
Old Jun 11, 2010 | 12:29 PM
powersmoked's Avatar
powersmoked
Did I miss something? Is there any reason you have not tried to read the codes?
*look real close for some black tape over the cel!
Old Jun 11, 2010 | 01:31 PM
chicagodragon
i had just noticed that the light dont work. it was running fine until the other day, so i never thought about it. i am going to try and pull codes later today.
Old Jun 12, 2010 | 03:35 PM
chicagodragon
ok, ni got the codes pulled today.... they are P0153,P0401,P0402,P1401,P1151,P1152. I looked them up on a list that was posted on here a while back and they are all EGR and O2 sensor related. is there a single underling cause for this? Iam working on cleaning the IAC, changing the PCV valve a looking for vacuum leaks, now. any help would be great. thanks
Old Jun 12, 2010 | 03:38 PM
alloro's Avatar
alloro
Intake gasket leak or a cracked PCV elbow at the rear of the intake.
Old Jun 12, 2010 | 04:11 PM
chicagodragon
on the upper or lower? should i just follow the PCV Valve from the valve cover and i will find it?
Old Jun 12, 2010 | 05:03 PM
alloro's Avatar
alloro
Upper intake gasket and the elbow is at the top rear of the engine. It's very difficult to see, you might have to feel your way. See the elbow in the upper right corner of this picture? Well that's what you're looking for.
Old Jun 12, 2010 | 05:26 PM
chicagodragon
i dinnt have an elbow. it looks like mine was replaced with a hose. my pcv was the origanal, and the iac motor was unplugged.,i tried to find vacuum leaks with carb cleaner. nothing came up. all this help is appreciated. please keep it comming. BTW i replaced the cel bulb, and no surprise, the light stays on.
