PHP tuned FICM
Old May 23, 2010 | 07:01 PM
  #91
Sarge261's Avatar
Sarge261
Thanks for the update Mark,
I have yet to order my DC power generator, but I am going to do it this week.
Which one did you get the 190, and what was involved in the wiring upgrade.
Sarge
Old Jun 24, 2010 | 11:54 AM
  #92
solaratomic's Avatar
solaratomic
Was there ever any update on benefits to the PHP FICM flash? Just curious.
Old Jun 26, 2010 | 03:27 PM
  #93
bismic's Avatar
bismic
Definitely resulted in some more power. Probably not a lot, but enough to notice. I had thought the fuel economy had come up by a half a mpg, but that is just not enough to show up as a "sure thing" on the fuel economy charting that I am doing.
All-in-all, I am happy with it.
Old Jun 26, 2010 | 03:51 PM
  #94
3KB's Avatar
3KB
Would you recommend?
Mark,
I have a FICM that is bad (19.5v as posted today on another thread) would your recommend a tuned FICM for anyone who was faced with replacing?
It is already studded, and I have a 64mm Non-VGT turbo.
Also i am faced with a having to replace this pretty soon. I have a 2800 mile road trip in a little more than a week.
Help!
Tim
Old Jun 26, 2010 | 03:52 PM
  #95
cheezit's Avatar
cheezit
tim what year is your truck?
whats wrong with the turbo?
Old Jun 26, 2010 | 04:02 PM
  #96
3KB's Avatar
3KB
It is an 04, the turbo went out year and a half ago when i had my first go around with the EGR cooler. It ate some metal somewhere along the line. After that, i went with a non VGT turbo for a couple reasons mainly because I have access to Schwitzer S300 turbos at work, shhh dont tell my boss.
It had been running rough lately and I just did a FICM voltage check and it was showing 19.5 v at idle so from all accounts, the FICM needs to go.
Old Jun 26, 2010 | 04:26 PM
  #97
bismic's Avatar
bismic
Originally Posted by 3KB
Mark,
Help!
Tim
You can try the solder repair yourself. The procedure is in the Tech Folder.
Swamps Diesel also repairs FICM's. You could send it to them, have it repaired, and then have them send it to PHP or Innovative Diesel.
Old Jun 26, 2010 | 04:56 PM
  #98
cartmanea's Avatar
cartmanea
Swamps can take yours as a core and send you one with PHP programming on it already.
Old Jun 26, 2010 | 05:08 PM
  #99
3KB's Avatar
3KB
I saw a detailed repair procedure for the "4 Screw" version of the FICM, but not for the "7 Screw" that mine is. Are they fundamentally the same? I trust myself with most things and repair, but electronics soldering,,,,,, not so sure i trust myself.
Old Jun 26, 2010 | 06:47 PM
  #100
npccpartsman's Avatar
npccpartsman
The repair is the same. On the row of 4 screws one end is 12v the other end is 48v. The two in the middle are labeled 5v gnd and +5v logic with gnd being next to the 12v. The three screw row you can ignore. They are gnd, clock, gnd, in that order. DON"T TOUCH THE CASE WITH THE PROBE while you are touching a screw.
bigbeariron
Sep 24, 2020 07:49 PM
DSMMH
May 19, 2016 10:23 PM
Kert0307
Jul 28, 2015 10:08 PM
the_auto_tech
Jan 20, 2015 01:26 PM
cay5628
Mar 11, 2014 11:55 PM
