wierd knock under load....
Apr 25, 2010 | 08:16 AM
Quote:
Originally Posted by
bashby
look closely at the balancer, can you move the outer ring
on the inner?
uhh..........NOOOO idea what your talking about....
Apr 25, 2010 | 05:53 PM
You said your harmonic balancer was wobling. The HB is a hunk of steel bolted to the crank with an outer ring of steel surrounding it, attached by rubber. Sometimes the outer ring of steel gets detached from the inner part (rubber deteriorates) making it wobble and possibly hitting the timing cover and make a knocking noise.
Apr 25, 2010 | 06:17 PM
no..it looks like the whole pulley..i tried to get a video but its going too fast to be caught by my mom's camera..and the crack pulley, and water pump pulley both look like they are wobbling..
Apr 25, 2010 | 06:23 PM
Reach down there and grab the pulley on the crankshaft and see if you can stop it ...
NO DON'T DO THAT!! I'm only kidding PLEASE PLEASE don't do that ...
TURN the motor off ...
Then reach down there and grab the crank pulley/Harmonic balancer and see if it/they move... BY HAND with motor turned off!
[edit]
Also do the water pump pulley.
Might want to loosen all the belts to do this, it'll work better.
[/edit]
-Enjoy
fh : )_~
Apr 25, 2010 | 06:28 PM
well i know for a fact the alternator and steering pump wobble...i still need a steering pump too....
May 1, 2010 | 07:25 AM
ok..well it use to miss while at idle, and after i put in the new plug it dont miss anymore and it runs realllyyy smooth at idle
May 1, 2010 | 12:29 PM
ohh and also, i let the truck completely warm up today and the plugs of the side with the oil were that really good tan color
May 3, 2010 | 11:39 AM
alright, i took teh ford for a little joy ride around my yard (either WOT or all brake) and there was NO knock, and a TON of power!! it was the 3rd plug that was bad haha
May 3, 2010 | 12:42 PM
Just follow the saying K.I.S.S. (keep it simple stupid)
May 3, 2010 | 12:45 PM
lol thats what i was doing xD i fixed what was broken!! tho i didnt know it was broken untill it came off haha
May 20, 2010 | 02:47 PM
im having NO luck finding the issue....
Raymgriff
17
Mar 26, 2017 06:26 PM
PEG
1997 - 2003 F150
Nov 18, 2015 12:55 PM
78fordman
Modular V8 (4.6L, 5.4L)
29
Feb 17, 2012 07:49 AM
viperrtblck
Jul 2, 2006 03:52 PM
Maxwelk9
16
Mar 20, 2006 03:23 PM
350 ,
46l ,
54 ,
engine ,
f250 ,
fine ,
ford ,
idles ,
knock ,
knocking ,
knocks ,
load ,
loud ,
timing ,
underload
