wierd knock under load....
Old Apr 22, 2010 | 11:57 AM
fepowerguy8's Avatar
fepowerguy8
as mentioned before knock can be caused by the distributer being advanced too far, pulling the plug wires will work. If it continues to knock after pulling the wires it is not a timing issue. A rod knock is generally lower in pitch then a knock caused by timing. If I recall correctly a timing knock would get worse sounding the more rpms you turn and the rod knock will be more noticeable at lower rpms.
Old Apr 22, 2010 | 12:08 PM
'83f3fiddy's Avatar
'83f3fiddy
if it was a timing knock then why would it have done it at 8* and then lessened at 10*
Old Apr 22, 2010 | 12:09 PM
'83f3fiddy's Avatar
'83f3fiddy
Originally Posted by JimsRebel
This is the best idea yet.
I would also do a compression test.
Jim
im trying to get my hands on a tester right now...been trying to for the past week...
Old Apr 22, 2010 | 12:33 PM
fepowerguy8
I'm not sure why it would get better, but as formentioned if you remove the wires and it gets better that will eliminate the timing knock. Is the knocking noise high or low pitched and were is it coming from in the engine? You can use a wood dowel or something to listen to where the knock is located if you do not have a stethascope.
It could still be a fuel issue as well, just because you put new fuel in it does not mean it's good, it might have water in it. Just a thought.
Old Apr 22, 2010 | 01:46 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
... Has to be moving ...
Is it Automatic??
Does it do it setting still in gear??
Does it do it setting still with Throttle Application, Brakes on??
Do you have to put a load on the motor??
Can you free rev it and get it to do it?? (ie: snap the throttle)
-Enjoy
fh : )_~
Old Apr 22, 2010 | 01:49 PM
mountaineer27's Avatar
mountaineer27
sounds like spark knock if you remove a wire and it gets getter
Old Apr 22, 2010 | 03:16 PM
'83f3fiddy's Avatar
'83f3fiddy
i go to the same station everytime, and i went there with both my trucks and my dodge has no knock at all, and was actually a bit more peppy with the 93 from the same pump i was at with the ford.
Is it Automatic??
-Enjoy
fh : )_~
auto yes, in gear yes, when i had a vacum leak yes but i fixed that. the trucks weight is enough load to get it to do it. and it ONLY happens when im inside teh truck in any gear and applying the gas to go faster.
only thing iv done with the wires is make them 8mm
Old Apr 22, 2010 | 03:19 PM
mountaineer27
doesnt really have to do with just wires, timing to, bad gas or fuel pump can cause it to. it would make more of a ping sound though.
Old Apr 22, 2010 | 03:22 PM
'83f3fiddy's Avatar
'83f3fiddy
it kinda sounds like someone beating on the block with a plastic hammer....thats the onyl way i can think of explaining it...
Old Apr 22, 2010 | 03:29 PM
mountaineer27
in my experiance when it sounds like a little man with a hammer its no good. bent rods, valves, shot bearings. could be a lot of things. could be a weak oil pump starving the heads for oil. i would pull the plugs and look down in with a light. see if the piston head is banged up. could be a broken piston ring and a little chunk of it is up on top of the piston. just saw that in a 350 last month on an engine tear down. maybe pull the valve covers off and look to see how dry it is or a bad valve.
Old Apr 22, 2010 | 03:32 PM
'83f3fiddy's Avatar
'83f3fiddy
i did the valve cover pull and i dunno about the bottom end but the top end is brand new!!! and im running 60PSI of oil at WOT during the knocking..
Old Apr 22, 2010 | 03:44 PM
Festus Hagen
Methanoholic
Sure you don't have an exhaust pipe or something hitting something ...
Doesn't sound like the motor internals to me. Maybe timing, you could adjust a couple degrees and see what happens to the sound.
[edit] If you're running it WOT it's not internal .. a 351 would have exploded by now! [/edit]
-Enjoy
fh : )_~
Old Apr 22, 2010 | 03:47 PM
  #28
'83f3fiddy's Avatar
'83f3fiddy
i still have to turn it back to 8*...and the only place the exhaust it touching anything in the mounts, and where it bolts into the block..
Old Apr 22, 2010 | 04:05 PM
  #29
Festus Hagen
Methanoholic
Do you have a way to capture the sound ... Video, Audio recorder ... Something so the peeps on here can hear it, It is extremely hard to diagnose sounds from explanations.
A knock to one is a ping to another!
-Enjoy
fh : )_~
Old Apr 22, 2010 | 05:03 PM
  #30
'83f3fiddy's Avatar
'83f3fiddy
i need a steering pump and a T cable before it can move...
