remove dash switch knobs
Old May 20, 2010 | 10:18 PM
334eagle's Avatar
334eagle
remove dash switch *****
i have a 1981 f100 and i am trying to remove the headlight switch **** an windshield wiper switch **** so i can remove the instrument panel . whats the procedure? help much appreciated
Old May 20, 2010 | 10:22 PM
Fordzilla80's Avatar
Fordzilla80
There's a spring behind the ****,it will need to be depressed to remove the *****.If you turn the ***** you will see a small section cut out.You will need to find something small enough to fit inside there and depress the spring.I took a small probe and bent the end into an L-Shape and use that to remove the *****.When you depress the spring,pull the **** towards you and it should come right off.Same goes for the Heater-A/C *****.
Old May 20, 2010 | 10:47 PM
ctubutis's Avatar
ctubutis
From Franklin2's diagrams:
Old May 20, 2010 | 11:05 PM
Franklin2's Avatar
Franklin2
On some of the headlight switches, if you can reach it, there is a secret little **** sticking down on the switch behind the dash, opposite the side the wiring is plugged into. You can go out and disconnect the battery, pull the headlight switch all the way out, reach behind the dash and push the little **** and pull on the switch, and the whole **** and shaft will come out of the switch.
This worked on my old 1980, but it's too crowded on my 89 to reach it, so it was fiddle with the retainer on it. Most of the time you end up just jerking the **** off, and then it never is quite right after that.
Old May 20, 2010 | 11:36 PM
newrider3's Avatar
newrider3
Sorry, couldn't resist.
Old May 20, 2010 | 11:55 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Amen!
-Enjoy
fh : )_~
Old May 20, 2010 | 11:57 PM
jcrowe15's Avatar
jcrowe15
I used a fish hook, works great
Old May 21, 2010 | 12:44 AM
Festus Hagen
Methanoholic
Great idea ...
-Enjoy
fh : )_~
Old May 21, 2010 | 06:08 AM
Ken Blythen's Avatar
Ken Blythen
In some years, the button on the light switch faced the opposite way - some up, some down.
I struggled to find mine the first time I removed it & found it was opposite to what I had been described - then later read of the change.
Old May 21, 2010 | 08:35 AM
Fordzilla80
If you do it enough,it comes extremely easy.
Sickos.
Seriously though,i've taken the wiper/windshield ***** off of these trucks so many times,it's not even a challenge.
Ripemdry
17
Feb 26, 2016 10:42 AM
DaveF-250SD
Nov 15, 2015 12:26 AM
Bird-Dog 250
Sep 13, 2015 12:11 PM
atomicjoe23
28
Jul 12, 2015 06:52 PM
SeaCarr
Oct 21, 2013 02:16 PM
