wierd knock under load....
Old Apr 22, 2010 | 06:29 PM
  #31
'83f3fiddy's Avatar
'83f3fiddy
so i pulled the passenger 4 plugs and all 4 were coverd in oil, and black as night. and teh passenger 4 were a dark tan/black and no oil what so ever.
i think i need a new head gasket on the passenger side..
Old Apr 22, 2010 | 06:49 PM
  #32
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Oil in the whole bank is not head gaskets.
Valve Stems
Rings
Pistons
Unless it's coming in the intake.
-Enjoy
fh : )_~
Old Apr 22, 2010 | 06:52 PM
  #33
'83f3fiddy's Avatar
'83f3fiddy
so i basicly have to rebuild a freshly rebuilt motor
Old Apr 22, 2010 | 07:34 PM
  #34
Festus Hagen
Methanoholic
I've seen more then one "Fresh Rebuilt" motor broken ...
IIRC you don't know that it's freshly rebuilt, it could have been slammed together in a swamp with old broken pistons and twisted rods!
I think you'll find it knocks all the time ... A Screwdriver, Stethoscope, Dowel would have pointed that out.
Pulling plug wires would also point that out.
You need to do a compression check before you pull it apart.
-Enjoy
fh : )_~
Old Apr 22, 2010 | 07:46 PM
  #35
'83f3fiddy's Avatar
'83f3fiddy
im gonna be getting a compression checker in a few days from my friend..but i have a feeling its a cracked head...
Old Apr 22, 2010 | 10:22 PM
  #36
ctubutis's Avatar
ctubutis
Rep points for that one... Unless you've got the paperwork from the machine
shop, you have absolutely no idea what's been done to it. One of the reasons
why I bought my truck was because of its "rebuilt" engine but with no
supporting paperwork. It started puffing oil on startup about a year later so I
pulled it out and took it apart to take a look, I was hoping for valve guides or
something easy like that.
Man, the jokers who put that thing together should have been exiled to Siberia,
it was CLEARLY not done in a professional manner. First clue was the handful
of blue RTV chunks in the bottom of the oil pan, second clue was the RTV that
had blocked the coolant flow through the heads, it looks like some dumass
put RTV on the head gaskets (pictures at https://www.ford-trucks.com/forums/7...ssageways.html).
Even in these forums, you'll read about people trying to "rebuild" their engines
themselves, merely by replacing a bunch of parts. Engine building is an art
AND a science that involves a LOT more than merely replacing components
and painting the outside....
A compression test will be telling..........
Old Apr 22, 2010 | 10:49 PM
  #37
Festus Hagen
Methanoholic
ctubutis,
It's funny you mention this, I have a Jeep 258 (4.2L) in right now that some "Professional ASE Certified Mechanic" in MI resealed the plastic rocker cover for some folks here in Maine while they were out there visiting, They are lucky they made it home, Most any other motor would have scattered with what I'm finding. Bearings are deep into copper, crank is wiped and best of all, A valve stem THROUGH a rocker, it's oiler hole up though the pushrod was packed full of Sillycone, so were several others but they are just deep into the rocker, not through. Not to mention the chunks of Sillycone and other debris found laying on the lifter way. Unfortunately the pan had been recently off and it and the pickup were cleaned so I didn't get to see what was there, and of course whoever did it used what looks like 2 tubes of red sillycone on a RUBBER pan gasket... A BIG NO NO ... Never use sealants on rubber gaskets.
One of the things I learned many years ago when buying was to look for Sillycone around gaskets... See Sillycone - Don't walk away, RUN!
First clue that a monkey's been in there.
Properly used, sealants should not be seen.
-Enjoy
fh : )_~
Old Apr 23, 2010 | 04:03 AM
  #38
'83f3fiddy's Avatar
'83f3fiddy
well im gonna rebuild the motor correctly...lol ill even have a motor build thread ^_^ it wont happen for a few months unless people wanna help me get it lol its under 400 bucks i just have no job right now >_>
Old Apr 23, 2010 | 05:16 AM
  #39
'83f3fiddy's Avatar
'83f3fiddy
also when i rebuild the motor some time after that i wanna put a super charger on the motor but i cant find anyplace for a charger other then turbo...and i liek turbo but i dont want a turbo on a truck..i want a super charger!!!
Old Apr 23, 2010 | 08:30 AM
  #40
fepowerguy8's Avatar
fepowerguy8
Paxton Superchargers
Old Apr 23, 2010 | 10:52 AM
  #41
'83f3fiddy's Avatar
'83f3fiddy
sweet,
here are the #1 and #4 plug and the #3 plug with the cold exhaust pipe, i think i know why it was cold...
Old Apr 23, 2010 | 11:12 AM
  #42
fepowerguy8
a broken plug will cause a knock. I've seen worse plugs, I've seen engines that have been rebuilt with chrome rings they take a long time to seat (around 5000miles) and that will foul up plugs if the rings have not seated yet as oil is blowing by.
Old Apr 23, 2010 | 11:23 AM
  #43
Festus Hagen
Methanoholic
I can't see them, The camera does not have macro capabilities and it cannot focus that close.
It's not a "Break In" issue, Look at the oil color, That alone speaks volumes!
-Enjoy
fh : )_~
Old Apr 23, 2010 | 11:30 AM
  #44
'83f3fiddy's Avatar
'83f3fiddy
but then why would the other side be dry? with no hint of oil at all???
Old Apr 23, 2010 | 11:32 AM
  #45
'83f3fiddy's Avatar
'83f3fiddy
-Enjoy
fh : )_~
and believe it or not that oil is under 150 miles...i put in 6 qts of 5W-30 Pennzoil about 125 miles ago..
