On your gaskets, can't remember the years/applications, but they made thin metal ones that also lapped up and over, kinda protecting the plug wires from heat. They were all metal, unlike the common metal-skinned asbestos type gaskets.
Just in case you need to put some on at a later date.
That I could get behind.
wish I knew how to look up moulded radiator hoses. I may compare my 76 f150 390 hoses and see if I could make them fit.
Most likely it's the same radiator as yours. I have a 4-core, much much larger tanks than a F-100
It's got the big super cooling rad . I looked on rockauto and there was actually more selection than I was prepared for. I'm going to do some measuring.
I sure wish I could find a proper air cleaner decal. I find 272,292,352 but no 330. I have searched everywhere to no avail.
Well its alive!! It runs well now. Sadly I could not make the original 2100 idle circuit operate correctly. I cleaned it multiple times to just no avail. The balancer timing Mark's seem to be off so I built a piston stop and made a new tdc mark. The carb that's on now is actually the original carb off the 360 that I used the block for this build.
The master cyl is locked up and i have never gotten the brakes to work even before the engine debacle. I did the pass rear wheel cylinders but I'm prepared to replace them again. I ordered fronts and the master and some hardware.
it seems there are 14 or 15" drums but i have 14". Shoes are not available so I'll have to get mine relined. I have a set of 15" drums I cant use from my parts truck. Bummer. And shoes..dang been hoarding them for nothing.
Either way this is me winning finally!
Oh yeaaaaa I forgot about that. I got one for like my 76 f150 390. It looked close and it fit perfectly actually.
Just talked to my dad and he says he will cover plates and put farm ins on it..sweet hope to be driving it in the next couple weeks with brakes lol
Assuming the rear end hasn't been changed out - give me the code from your warranty plate for your axle and with that info I should be able to look up those gaskets. There's a chance I have a small stack of those gaskets here.
My stack of gaskets are 5 17/32" O.D. and 4" I.D. (A8TZ-1001-A) so likely not correct for your truck. If you measure the O.D. of your flange that might be all that is needed. 5 7/8" is 15M axle and 6 3/16" is 16M axle.
F8 code. Eaton 13802. These idiots were no help. I should have gone to the other place that I like better anyway.
Fail
I've extracted the page of applicable gaskets. This is Section 10 Page 1 of the MPC, which is the first page of actual part numbers.
I'd guess it's the B4TZ-1001-A but probably best if you measure yours and compare to the attached PDF list. Yours are 8 hole which eliminates some of them.
Here's one more page with some of the axle codes for 1964/65 and it shows F8 is the Eaton 13802 in a 15M (15,000 lbs) rating for the axle itself, which seems to jive with the B4TZ-1001-A, I believe.
