auto trans possable issues
Old Apr 25, 2010 | 08:05 AM
  #31
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by wiccantoy
A external trans cooler was also put on but had to be piggybacked onto the stock one. Aparently the stock one has a thermastat inside to tell the trans when it needs new fluid.
No, that's not right. The stock coolers do not have any type of thermostat from the factory. They flow ATF anytime the engine is running.
Old Apr 25, 2010 | 09:14 AM
  #32
wiccantoy's Avatar
wiccantoy
than why was the trans temp rising after 2 miles. and now the trans temp is staying normal after the cooler was piggybacked to the stock one?
Old Apr 25, 2010 | 09:40 AM
  #33
billfishnut's Avatar
billfishnut
I have to agree with Mark. I rebuilt my trans and added an additional cooler. In short, you have probably tripled your cooling capacity.
Old Apr 25, 2010 | 09:47 AM
  #34
wiccantoy's Avatar
wiccantoy
i understand the fact the cooling has been doubled or trippled. i just dont understand why it would get so hot untill i used the stock one as a piggy back
Old Apr 25, 2010 | 09:57 AM
  #35
billfishnut
Talking
Ok, so you had an aftermarket cooler flying solo and it got hotter? If so, that is weird and I don't understand why it would happen that way but I am 99.9% sure that the stock oil cooler is just a bent up pipe with fins. No magic.
The only reason to put a thermostat in an oil cooler loop would be to heat the trans. I am not aware of any manufacturer that would do that.
I could be wrong, just ask my wife.
Old Apr 25, 2010 | 10:15 AM
  #36
wiccantoy's Avatar
wiccantoy
I'm not sure y. My tranny guy said if it has a thermostat inside that would make sense. If not it would send trans fluid through the torque converter at a high rate and alow it to start to heat up.
Old Apr 25, 2010 | 05:11 PM
  #37
Mark Kovalsky
Ford does it, but not on the E4OD or 4R100. The TorqShift trans has an internal thermostat.
That doesn't make any sense. There is no thermostat anywhere in your trans unless someone added one after the truck was built.
Old Apr 25, 2010 | 05:50 PM
  #38
wiccantoy's Avatar
wiccantoy
Not sure trans is from a 01 f550 with plate for hydrolic unit
Old Apr 25, 2010 | 06:25 PM
  #39
Mark Kovalsky
I'm sure. That's a 4R100 and it DID NOT have a thermostat.
Old Apr 25, 2010 | 07:32 PM
  #40
wiccantoy's Avatar
wiccantoy
yes im 99.9% sure it is a 4R100 i just dont understand why it would have heating issues with a larger than need brand new cooler. Than works fine when useing both
jeff299
15
Jan 18, 2012 06:59 AM
4EXTRDR
Nov 2, 2011 10:28 AM
HighOctane
44
Jul 23, 2009 08:10 AM
njstevens
Feb 22, 2008 08:47 PM
chesterstroker
19
Jan 27, 2007 11:53 AM
