Do I need a DP Tuner update...shift kit?
This may seem odd, but it seems the truck has a little less "go" then before (tight converter?) and it doesn't coast as freely as before....I also believe I "hear" the pump in the trans moaning a bit.......The trans feels fine, my one thought was when I had the DP burned for this truck, it had a stock trans...Does the TransGo shift kit affect the DP tune and does it need to be addressed? COuld this be part of what I am feeling in this trans? ....Wondering if maybe the line pressures are too high now between the DP & the shift kit. Thanks for any info - Bob
My Coast Clutch apply piston seal lip was damaged from the factory and I never felt what it should really be like until I rebuilt the trans and replaced it. You would have to ask your rebuilder if this was the case. You will feel some "drag" when coasting. That is the Coast Clutch doing its job along with the DP tuning holding the TC lockup down to a lower speed.
The DP tuning and TransGo shift pressures will stack and increase line pressure to the clutches. If it feels too firm, then you would need Jody to reburn the chip or make adjustments to the shift kit, if possible.
YES.. YES YOU DO.. Okay, now I need to read your post..
After reading your post, now i need to read what others said, so I dont repeat..
My Coast Clutch apply piston seal lip was damaged from the factory and I never felt what it should really be like until I rebuilt the trans and replaced it. You would have to ask your rebuilder if this was the case. You should feel some "drag" when coasting. That is the Coast Clutch doing its job along with the DP tuning holding the TC lockup down to a lower speed.
I say try it and let us know.
Diane
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Diane
