Offroad & 4x4
Dillins Build Thread
Old Nov 14, 2010 | 06:20 PM
  #676
fatdan460's Avatar
fatdan460
that pitman arm is extr3333me!!!!! should turn 44's with ease
wtf is that? a long half inch wrench with flat stock on it? it's a huge improvement over your slap-chop diff cover :flipoff:
Old Nov 15, 2010 | 02:43 PM
  #677
thekingofcows's Avatar
thekingofcows
Have you considered locating tie rod ends above your steering arms for a little better angle?
Old Nov 16, 2010 | 06:44 PM
  #678
alpha/omega's Avatar
alpha/omega
Cows is right, put your tierod and draglink on the top of your steering arms Dillnuts.
Old Nov 16, 2010 | 08:26 PM
  #679
dillinewton's Avatar
dillinewton
thank you, that didnt even cross my mind.
Old Apr 10, 2011 | 09:43 AM
  #680
dillinewton
Well here are the most recent updates. hope you like.
Old Apr 10, 2011 | 10:10 AM
  #681
crazyredneckanyhow's Avatar
crazyredneckanyhow
Everything seems to look pretty beef. Only thing i see that needs work is your design on brackets. Such as the radius arm bracket. Put more of a radius on your corners when building things. Dont just put a 90* angle on everything. Makes it look like you used whatever you had and just drilled holes in it. A little bit of extra work makes things look a million times better.
Old Apr 10, 2011 | 11:28 AM
  #682
dillinewton
I feel like that would be more of a personal perferance, than anything. I didnt have the plaz table like I did when I built everything else. Just the shear so everything was identical, using the hand plaz, stuff isn't quite as perfect. Also didn't say that all the guts are in the axles. detriots with 5.38s
Old Apr 10, 2011 | 12:28 PM
  #683
73 ford guy's Avatar
73 ford guy
Looks good Dillnutz. The steering arm is that just the splined section on a stock one modified to work. Also as for heim ends guys do those have any slop in them compared to a tapered regular rod end? What's the advantage I always thought a tapered one would give better Steering response. Let me know if that's not the case.
Also as there is so much custom work here would it ever be street legal if pulled over or is this a trail only truck? If it is a trail truck I would opted for a full hydro steering setup as you already run coils and it would flex awesome eliminating the draglink completely.. I want to run coilovers real bad and it's next on the list.
Old Apr 10, 2011 | 05:40 PM
  #684
dillinewton
yepp stock spline section of the pitman arm. just draft in 1/4 inch around it to make my steering box go lock to lock, not the stops on the hubs. idk ill prolly cruise it everyonce in awhile. yess i will be putting hydro assist on it. and i quite didnt understand what you ment by the hiem joint question.
Old Apr 10, 2011 | 06:03 PM
  #685
73 ford guy
Hydro assist will work good but I meant full hydro would be even better if it's an offroad truck as you lose the draglink allowing Flexy suspension travel.
With the heims I meant the bolts slide in a sleeve is it a precision fit or does it have some play as minor as it may be. Again this is why I always thought a tapered tie rod end is better.
What kind of steering box are you running? Do you have an idea where tap for hydro assist?
Old Apr 10, 2011 | 06:09 PM
  #686
73 ford guy
O also what size bolts are holding your steering box on? Are they 7/16 stock size? I would definitely drill it out to either tap to a minimum 1/2 "course thread or drill a **** hair bigger and run a through bolt with a nut on the backside with lok tite, all grade 8 of course..
I snapped mine off all 3 on my first good 4x4 test with new 7/16 grade 8 bolts. It was really one of the few breaks I've had..
Old Apr 10, 2011 | 07:10 PM
  #687
fatdan460's Avatar
fatdan460
dillin if i read that right, that's no good.
are you saying instead of letting the steering hit the stops on the knuckles like it should, you made it so the box itself can go through it's full rage and bottom out itself? if that's what you did you effed up. put some stops back on there just a little out from full lock on the box otherwise you are going to stress the living foock out of that box, frame rail, and you will probably bust your sector shaft way easier than they already break.
maybe i read it wrong
Old Apr 10, 2011 | 07:25 PM
  #688
dillinewton
everything will stop together. the stops on the hubs and the box together. its not a trail rig, just mud bogs. the bolts are very snug in the hiems. no i dont know where to tap for assist.
Old Apr 10, 2011 | 07:44 PM
  #689
alpha/omega
Looks damn good dillweed.
Ill email you some pics of where to tap a 250 box for hydro assist.
Old Apr 14, 2011 | 04:50 PM
  #690
alpha/omega
Looking back at your pics...
That pitman arm is teh ****. I also really like the design of the lower coil bucket/trac bar mount.
The bolt that hold the radius arms to the upper radius arm brackets seem a little small (appear to be 1/2", MAYBE 5/8s) Id really like to see that 1" or at minimum 3/4 and definitely grade 8 or better. What type of joint or heim do you have there? and what size is the shank?
When are you starting the engine build?
