lifted truck
ya i have all that stuff im doing it allthe right way, are dana 60s setup for coil springs or do you have to fab it up yourself? i have some buddies that wheels the crap out of there stuff....they just put it to the floor till something breaks or they get out and all they have is dana 44 up front and they usually dont brake much. sometimes some hubs. yes i want to upgrade axles what would you guys suggest would be the right set up?
also im putting hydraulic steering on it, pretty much im tryin to make the best truck around here, which isnt really sayin a whole lot, cause everyone just stuffs the truck with the biggest tires possible and goes for it, but im buildin a motor, have the bare frame sitting in the shop and trying to make an awesome truck.....i would be very welcome to suggestions??? this is my first play truck most people just drive there trucks for work around here dont have the money to build play rigs thanks alot
Full hydro or hydro assist? Full hydro is not DOT legal. Not only that it is dangerous at speeds above 30 mph, due to the way the orbital valves are designed.
If you steer a normal car left and let go of the wheel it will naturally straighten back out. However with full hydro, if you do the same, it will continue to keep turning left. You have to manual straighten it back out. But when you do so, your now turning the wheel back to the right. Which in return will do the exact same thing. It will be a very sharp and dangerous maneuver.
I've had my trucks in offroad situations, just ***** to the walls across a mud pit and had several flip over experiences. Just imagine what it would be like on dry, grippy pavement! Just a suggestion. Hope your build goes well.
mxracer3276
03-08-2010 08:18 PM
