Starting issues. Please help!
I got only 4 of the injectors rebuilt today. Long tedious process.
I've run into a problem and I'm unsure how to fix it. I now have measurements A and B within tolerances but C is contacting enough that it is hard to get my .0015 gauge out when the solenoid is energized.
Jim's kit says nothing about how to correct it other than to contact him. I'm wondering if you know what I need to do to get this back into check. From everything I read it appears that if the armature contacts the solenoid it will eventually lead to failure.
I obviously don't want that. After getting A and B back in check with his shim pack C seems to be the same as before the rebuild. I know it is supposed to be over .002 but am I right with my thinking that it may cause problems later on if I don't correct the issue?
I'm running out of time before I have to move and I'm pressed to get this done as soon as possible with as little money out of pocket as possible.
I may have to throw in the towel and find another set of injectors to throw in for now to get the truck running.
Any thoughts are appreciated.
I was able to rebuild the last four injectors in just over 2 hours. It took me close to 6 hours to do the first 3 so learning curve played a big part in it.
I don't know when I'll be able to get them to or back from a machinist so I'll update as soon as I can.
Have you found work yet? There is work up here in the oil field if you are interested.
Glendive Job Service Workforce Center
I will let you know, stay tuned for more updates!
I believe I finally have this problem licked!!
Today I was able to get the armatures precision ground ($35) and everything back into tolerance. Re-installed the injectors and put everything back together.
It took a little bit of cranking to get all the oil back to where it was supposed to be (20 seconds at a time followed by about 10 minutes of cool down to not burn up the starter)
Then it finally started cold!!! It ran like crap for about 2 minutes and smoked like you wouldn't believe. The nieghbors didn't like it much. Then it settled into running okay but still smoking. I called a friend of mine who told me that was normal and took it on a 23 mile run with about 15 of that being freeway.
All I can say is WOW!! The difference is huge!! The rear tires will break loose (granted I have fairly worn out tires) without hardly trying. Before it seemed like a dog and wouldn't get out of it's own way.
The power was very good all through the throttle range, and could pass anytime I wanted on the freeway. After a few miles of driving the oil finally got all the air out of the rails and the idle smoothed out and it ran even stronger.
I will know for sure in the morning but I believe I finally have a good running truck.
I already bought a used DP-tuner from another forum and should have it next week after having it reburned.
One of the big things I noticed is that the engine cranks over much faster. I realized (after a talk with my friend) that it is because the engine is actually helping while trying to start!
Over all this issue has been a huge PITA but I've learned so much and have my truck running like a scalded dog for way less because of the problem so I shouldn't complain.
I will be ordering new rear tires and gauges tomorrow.
If anyone has questions please post up or PM me.
I would highly recommend Rosewood diesels DIY stage 2 kit for anyone wanting to pick up some easy horsepower while correcting older injector issues.
I'll update again tomorrow if anything else has been noticed, or missed
Have a great night everyone!!
CrazyKen
Gauges are on the way and I will install them as soon as they arrive, probably early next week. DP tuner should be here next week as well.
Thanks for the encouragement and kind words from everyone through out this fun trying month!!
It started up smoothly and quickly this morning with no issues!! That is the first time is has ever started up cold since I bought it. The PO just plugged it in all winter, masking the problem he didn't know he had (or at least that is what he still says).
CrazyKen
