HELP!!! PSD WONT START
Old Dec 31, 2009 | 06:50 PM
  #76
CPUNeck's Avatar
CPUNeck
Originally Posted by dthompson
well i thought this battle was over....go out this morning and wouldn't start....same thing....wts light is on...will start on ether what could cause it to not be getting fuel? ran fine last night...
Ok, this is with the chip out and batteries @ => 12.5 volts right. First thing, man you gotta stop using the ether. I know you may want it to start, but you can't imagine how much damage this stuff can do to your engine. The flash point of this stuff is no where close to #2. You could be touching off a charge in opposing cylinders causing down right carnage. [/Soap box off]
When you say it's not getting fuel, what leads you to that conclusion... is there no smoke? Does it sound like it's hitting on a few cylinders here or there while attempting to start? What does your fuel filter look like. Is the fuel bowl full when you open the lid? When it is running and up to operating temperature, at idle does the engine sound like a "knock" or more of a higher pitched "Ting". The "Ting" could be an indication of fuel starved injectors do to lack of fuel flow.
A rudimentary test of the flow is to attach a hose to the metal tube exiting just in front of the passenger side exhaust manifold, open the water separator valve at the rear of the fuel filter housing, and drain contents ~24oz. Then place a graduated container under the hose, and cycle the ignition to the on position. Time it for 30 seconds and you should have ~ 70oz's or more in your container. Again, this is just a rough test as there is no resistance to flow to speak of. This should be a start.
Old Dec 31, 2009 | 07:20 PM
  #77
dthompson's Avatar
dthompson
ok....drained the fuel bowl thing and as soon as the ignition was turned on it was full again i don't think its going through to the injectors i'm just guessing....i'd like to fix this or she is getting hauled to the stealership cause my dad is being a baby and thinks they should just work on it!
Old Jan 1, 2010 | 08:12 AM
  #78
CPUNeck's Avatar
CPUNeck
Well we're trying to not guess here, did you try filling a container for ~30 seconds? Just refilling the bowl in "as soon as the ignition was turned on" doesn't tell us much. Soon as for you may be different than soon as for other guys.
Why do the think there's no fuel getting to the injectors? Does the filter look old, do you know when it was changed last? May be time to go ahead and replace it. How much fuel is in your tank? How cold has it been. Have you put any additives into the fuel? Gelling could cause this.
Old Jan 1, 2010 | 09:34 AM
  #79
dthompson's Avatar
dthompson
The filter is all but brand new....full tank of fuel....was treated when i bought it and i treated with powerservice. only been bout 30 degrees...
Richadortiz
Jan 17, 2016 05:50 AM
f250man96
Nov 13, 2008 07:55 AM
bigbubba87
Nov 30, 2007 01:52 PM
pr099
Apr 10, 2004 09:45 PM
Wyobuilder
Aug 18, 2003 03:46 AM
