HELP!!! PSD WONT START
Old Dec 29, 2009 | 09:25 PM
  #46
tdpower's Avatar
tdpower
re
Originally Posted by PaysonPSD
When a scantool cannot estalish a connection it means the PCM is not getting power.
Upper left corner of this Power Distrbution diagram is the path to supply power to the PCM. With key on or in start power goes through under dash fuse #30 to the PCM Relay Diode to the PCM Relay winding to ground. If you can't feel the PCM relay operate it has to be a problem along that path.
It could also be a blown fuse that will not allow for the connection. IIRC it is the the power point/cig. Also, an incompatible program may cause this.
Old Dec 29, 2009 | 09:38 PM
  #47
PaysonPSD's Avatar
PaysonPSD
The scantool not finding the OBDII port (blown cig lighter fuse) and not being able to connect are two different things. Is it not finding the port or not connecting to the PCM????
Sometimes I get so frustrated not being able to be right there to help. GRRRRRR.
Old Dec 29, 2009 | 10:02 PM
  #48
dthompson's Avatar
dthompson
using a grey cps....i know how you feel....i wish someone was here to help.....i think it was unable to connect but i'll try tomorrow and check the cig lighter fuse...
Old Dec 29, 2009 | 10:11 PM
  #49
medhvac's Avatar
medhvac
thats the same color one i put in after my black on went bad,grab the spare one in your glove box and put in and see if it works!
Old Dec 29, 2009 | 10:13 PM
  #50
dthompson's Avatar
dthompson
saying grey is bad....????
Old Dec 29, 2009 | 10:16 PM
  #51
medhvac's Avatar
medhvac
i didnt say that i said grab that spare in your glove box and put it in!
Old Dec 29, 2009 | 10:17 PM
  #52
dthompson's Avatar
dthompson
don't have a spare...lol this one is brand spanking new!
Old Dec 29, 2009 | 10:20 PM
  #53
tdpower's Avatar
tdpower
Check the voltage on the fuel pump. Color does not matter if it is an aftermarket. Just my .04 cents adjusted for inflation.
Old Dec 29, 2009 | 10:24 PM
  #54
medhvac's Avatar
medhvac
sorry but anyone that owns a 7.3 has a spare cps in there glove box! new or not!sorry man id go get another one and try it what ya got to lose?
Old Dec 29, 2009 | 10:27 PM
  #55
dthompson's Avatar
dthompson
i know but i think its bull if a brand new part doesn't work....may try it but that shouldn't make the wts light come on should it....
Old Dec 29, 2009 | 10:32 PM
  #56
dthompson's Avatar
dthompson
i'll check the fuel pump tomorrow...but the cps is not aftermarket...it is FORD...
Old Dec 29, 2009 | 10:39 PM
  #57
tdpower's Avatar
tdpower
What does a cps have to do with a wts light?
Old Dec 29, 2009 | 10:41 PM
  #58
dthompson's Avatar
dthompson
NOTHING THAT I KNOW OF!!!! that is what i'm saying i have no wts light that is y i don't think the cps is bad....
Old Dec 29, 2009 | 10:47 PM
  #59
tdpower's Avatar
tdpower
That is why I was trying to get you to check the voltage at the fuel pump. My other thought is your not building enough hpop pressure to fire the injectors. Are you getting any codes?
Old Dec 29, 2009 | 10:48 PM
  #60
dthompson's Avatar
dthompson
as i said earlier the scanner couldn't establish a connection....
