HELP!!! PSD WONT START
Old Dec 27, 2009 | 06:41 PM
F350-6's Avatar
F350-6
The link is saying don't pay Ford to change the part for you. It might take them 3 days and they sometimes charge $250 for something you can do yourself in less than 30 min. Of course if the recall hasn't been done, let Ford do the work for free. Just make sure you decline any other work the recommend.
Old Dec 27, 2009 | 07:05 PM
dthompson's Avatar
dthompson
OK....new problem....i swear to god the wts light was on earlier....i went out and just wiggled the cps connection hoping for a loose connection....now no wts....thanks guys
Old Dec 27, 2009 | 07:16 PM
F350-6's Avatar
F350-6
That's usually a blown fuse. Check fuse #30. If it's blown, unplug your fuel bowl heater, install a good fuse (leaving the heater unplugged) and try to start.
Old Dec 27, 2009 | 07:17 PM
dthompson's Avatar
dthompson
fuse is good.....
Old Dec 27, 2009 | 07:19 PM
CPUNeck's Avatar
CPUNeck
Originally Posted by dthompson
fuse is good.....
Did you test it, or just pull it out and visually check it.
Old Dec 27, 2009 | 07:35 PM
dthompson's Avatar
dthompson
visually but will test it in a minute....just turn the key on and use a test light and check both sides?
Old Dec 27, 2009 | 07:41 PM
CPUNeck's Avatar
CPUNeck
Yep, that's one way. If it's blown, disconnect the plug ~2" from the top, at the rear of the fuel filter bowl. It'll be a two wire connector. Then replace the blown fuse, and try to start. Just leave the plug on the filter housing undone, at least for the time being.
Old Dec 27, 2009 | 11:27 PM
dthompson's Avatar
dthompson
checked the fuse with a test light and its good....putting cps in tomorrow evening will let you know thanks guys
Old Dec 28, 2009 | 06:48 PM
dthompson's Avatar
dthompson
Ok....just replaced the cps and still wont' start...still no wts light either tested fuse 30 and it is good....now what?
Old Dec 28, 2009 | 07:19 PM
F350-6's Avatar
F350-6
Let's start over. All fuses (not just #30) check good with a test light? Tried swapping the relays around with each other? Engine oil full? Fuel tank full of diesel (noticed you recently filled up - no gas right)? Any chance the fuel is gelled? Is the fuel bowl full of fuel? Is there any smoke or odors coming out the tailpipe while cranking? Where did you get your new CPS and did you plug the connector back in? Is the tach moving while cranking?
Old Dec 28, 2009 | 07:32 PM
dthompson's Avatar
dthompson
All fuses test good with test light. swapped relays? as in the blower with pcm? yes...just changed oil since it was low and needed changed anyway. full of DIESEL. fuel shouldn't be jelled only in the 30's and treated. Fuel bowl is full...no smoke or odors...cps came from ford...yes its plugged in and tach doesn't move while cranking
Old Dec 28, 2009 | 07:51 PM
CPUNeck's Avatar
CPUNeck
Have you tried wiggling the harness over the driver side valve cover while some one was watching for the WTS light and listening for the fuel pump? (with ignition in the on position obviously)
Old Dec 28, 2009 | 07:58 PM
  #28
dthompson's Avatar
dthompson
just did no luck....
Old Dec 28, 2009 | 08:07 PM
  #29
CPUNeck's Avatar
CPUNeck
Ok, so you have no WTS, any other lights come on? Time to break out the manual and look for the fuses for the PCM. Then with the ignition in the on position, make sure the circuit is live... if you've already checked all the fuses, now you need to ensure the PCM fuses are getting juice when they are suppose to.
Old Dec 28, 2009 | 11:50 PM
  #30
dthompson's Avatar
dthompson
with the key in the on position all fuses test good.....don't think glow plugs are on....the battery guage never moves up or anything....thanks guys
