460?
Old Jan 3, 2010 | 02:57 PM
  #76
Blown 331's Avatar
Blown 331
Originally Posted by monsterbaby
if you go back to carb you will need to either find a way to adapt a carb to the fuel injection manifold or swap heads. You can't interchange the intakes on those heads, that is why they don't interchange. a regular carb intake won't work on the FI heads.
Any idea what is different? Different angles, ports in different location? Etc.
Old Jan 3, 2010 | 04:32 PM
  #77
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Originally Posted by Bear 45/70
There is an adapter available to mount on the EFI intake that lets you run a carb on the EFI heads/intake combo. But for the life of me I can't remember who makes it.
Price Motorsports.
Look under carb spacers for part# CS-460EFI
Old Jan 3, 2010 | 09:13 PM
  #78
monsterbaby's Avatar
monsterbaby
IIRC the ports are slightly off and the bolt holes don't line up. As I remember it they had to move some of the bolts slightly to allow for the fuel rails. I just know that you can't bolt them up.
Old Jan 7, 2010 | 02:01 PM
  #79
billg302's Avatar
billg302
If I remember right, the D0VE heads will bump up compression a little.
ironman1977
65
Dec 27, 2020 06:19 PM
adam83
41
Aug 20, 2015 12:01 PM
Hyperactive460
Apr 4, 2015 11:06 AM
dreddybear
Jul 7, 2006 12:59 PM
