Old Mar 31, 2015 | 05:12 PM
Hyperactive460's Avatar
Hyperactive460
1978 460
i have a 78 460 that i pulled out of a motor home to install in my 78 F250 4 x 4. i've heard that these engines arent very good for this use, is this true ? i pulled these numbers off the block. D1VE - 6013 A2A and these off the heads D3VE A2A.
any help on this is appreciated, thanks.
Old Mar 31, 2015 | 05:51 PM
85e150's Avatar
85e150
Generally 460s and most other late '70s to early '90s motors are all pretty soft on power compared to mid '60s powerhouse motors, and new stuff that makes over 1 hp per cube even in economy cars. The motor home 460 isn't going to be much different than any other pickup 460.
Are you going to go through it, or just hoping to do a low buck swap?
What do you want, and what are you swapping out?
IMO I would not go through a 460 swap unless I was getting a lot more power for my repower dollar.
Old Mar 31, 2015 | 05:57 PM
Hyperactive460
the engine only has 43,000 original miles on it, my truck has already been converted over to accept a 460 swap. just looking to drop it in and hopefully go.
Old Mar 31, 2015 | 06:12 PM
85e150's Avatar
85e150
Should be drop in but remember the change in balance in the 460 somewhere in '79 maybe. (not sure) Just make sure your "new" motor balance matches what you have. (If I understand you to say you are already running a 460)
Old Mar 31, 2015 | 06:17 PM
Hyperactive460
yes i was currenty running a 460, blew a head gascket and the rings were shot. grabbed this one for 300 bucks.
Old Apr 2, 2015 | 10:43 AM
cbakker's Avatar
cbakker
Those motors should be nearly identical, but the new one may have a bigger cam. Still not a lot of power though. If it is power you want, deck the block to get the CR bumped up a bit and consider swapping heads. If you do not want to go through all of that, at the very least consider swapping the cam timing set for a pre-72 straight up set. The 88-97 sets should also work.
Old Apr 4, 2015 | 11:06 AM
Hyperactive460
right now i'm just looking to drop the motor in, i have a 1970 460 in the garage but it needs to be gone thru and i dont have the money right now. i just want the truck to be a dog is all.
mjeas
Jul 7, 2011 04:27 PM
i1dery
Aug 16, 2005 12:07 PM
dino360
Engine Swaps
Jul 12, 2005 08:31 PM
BigBlockBill460
Jan 17, 2004 06:59 PM
rjcline
May 10, 2002 12:12 PM
