Nothing here yet. As a matter of fact, I was smokin up Cedar Rapids runnin the truck around in 120 race this afternoon because we had dry roads for once.
Got some flakes, quite a bit of melting, as it is 34 degrees... not looking like it will amount to much. probably will dump on me since I unplugged the tractors... I did get one of the lift arms fixed though. It was a good 4" higher than the other side. The threads are stripped, so the fix of choice my uncle or father used was to drill a hole through, so I drilled the hole in the right place to be level, hopefully the hole they drilled doesn't break off...
60" cycle country atv snow plow, manual lift available, also have mounting plate for honda or polaris $300. 319-231-2535
* it's NOT ok to contact this poster with services or other commercial interests
PostingID: 1568526951
Up just east of Waterloo...
Thanks Roger. I can buy one online from warn, with mounting equipment and lift for a Yamaha delivered to my door for $500. Not a bad deal and is probably the route I'll end up going.
