Coolant Change 101
Old Mar 13, 2015 | 04:14 PM
  #181
Rusty Axlerod's Avatar
Rusty Axlerod
Originally Posted by Bordeauxman
Pardon my ignorance, but what ELC coolant is recommended? I have Ford Gold in there now and I see that the ELC is more and more the recommended coolant.
The local NAPA store has Zerex. Would that be suitable?
Thank you in advance. Jeremy
A couple years ago when I did my coolers I drove to a nearby city to get the CAT coolant. Logic being if they wrote the standard everyone is sighting it must be "best". I'm not quite so fussy anymore. I found my local Tractor Supply Store had Rotella coolant that was just fine.
Anything that is SILICATE FREE and meets the Cat EC-1 standard will say so on the label and work just fine in your truck.
Yup, Napa carries Zerex Extended Life Part #ZXED that would be good.
Oreilly's carries Final Charge Global Part #FinalCharge
I believe Delo makes one also.
John Deer has a silicate free ELC (I think it's green though, may make for some confusion later)
There are several more I can't think of right now
Old Mar 13, 2015 | 04:24 PM
  #182
P-38's Avatar
P-38
I used the Zerex G-05. Got it from O'Reilly's for $18.99/gal.
Old Mar 15, 2015 | 11:36 AM
  #183
BPofMD's Avatar
BPofMD
Veteran: Navy
GO-5 is the same as Ford Gold.
Old Mar 15, 2015 | 04:09 PM
  #184
Bordeauxman's Avatar
Bordeauxman
Wonderful. I bought the Zerex GO-5. I should have looked more closely at the label. I've since looked at Zerex website and it looks like the "extended life" version has the CAT-EC1 rating so i'll be heading back to NAPA next weekend.
Old Jul 1, 2015 | 04:53 PM
  #185
ves83's Avatar
ves83
I have 134k on my truck I took my truck to the dealership and had the coolant system flushed at 119k when I bought it on the highway not towing my eot runs 215-219 depending on hills and my ect runs 202-214 depending on hills. I plan on doing a flush with vc9 tomorrow I had to order my coolant. Is there anything alarming about these numbers they just seem high. The high spike of the coolant temp will come from a steep hill and last for about 3 seconds and then drop back down same for the engine oil temp 219 is a spike that last for a few seconds and drop down to 215-216. My delta not towing sit at 14. After reading this entire thread it just seems high. I'm also running the 8k Tow from Gearhead.
Old Jan 6, 2016 | 09:36 AM
  #186
NotURMailman's Avatar
NotURMailman
I hate to revive such an old thread, but it seems like the appropriate place for this question. I plan to flush and refill with Rotella ELC. It's unclear if the Ultra ELC meets the requirements of this engine, but the ELC clearly does. Maybe someone who is more of a chemical engineer than me can answer that question. I would think the Ultra would be a better all around coolant, but maybe not?
Here is the Rotella data sheet:
http://s07.static-shell.com/content/...s-brochure.pdf
Old Jan 6, 2016 | 06:45 PM
  #187
Rusty Axlerod
I think in a nutshell the "Ultra" is comparable to Ford Gold. It doesnt say silicate free or even low silicate for that matter. The Rotella ELC states silicate free and meets CAT EC1.
Old May 1, 2016 | 07:26 PM
  #188
Pipedr's Avatar
Pipedr
From what I can find online the Ultra is silicate free and meets EC 1. A quick google search and you can find the technical data sheet from Shell. I am debating using this coolant also but haven't heard of many people using it. Maybe because it's still relatively new
Old May 1, 2016 | 08:29 PM
  #189
Rusty Axlerod
Here: http://s07.static-shell.com/content/...s-brochure.pdf
Ultra is nitrate free (not silicate free) and not EC-1 rated.
Rotella ELC is EC-1 rated, which includes no silicates.
Ultra sounds like it would be better but I was all over the bottles in my local Tractor Supply store. The ELC is what I choose for my truck because it is silicate free. I would point out that the Small amount of silicates in the ELC isn't enough to cause an issue like the old green coolant can. Many people have ran many miles on the Ford Gold without issues, I suspect the dose of silicate in the Rotella Ultra is similar to Ford Gold.
Old May 29, 2016 | 11:39 PM
  #190
siesta's Avatar
siesta
I think I've read elsewhere that the drop-out of silicates has some relationship to the duty cycle of the engine. If your engine is prone to high heat from always running loaded or whatever, you're going to suffer silicate drop out if they are present (not good for our oil coolers obviously). If that is the case, probably not a good idea to run Gold or anything close to it. If you just have light duty, then maybe its not an issue. This would also suggest that change frequency is less of an issue than actual type of coolant involved.
This is just from what I've read, and the silicate drop out I've observed from my own engine that is always loaded (in a big RV).
Old Aug 15, 2016 | 02:25 PM
  #191
bluera1028's Avatar
bluera1028
What is the recommended interval for flushing the radiator?
Old Aug 23, 2016 | 03:53 PM
  #192
texastech_diesel's Avatar
texastech_diesel
Token Redneck
30k on Ford Gold/ G-05 coolant; 100k on ELC specified by International for the VT365.
lorenambrose
3.0L V6
Jun 26, 2010 07:53 AM
mattrabel
Apr 4, 2010 05:15 AM
bismic
Jan 1, 2008 04:16 PM
Flip4ford
Kansas Chapter
Jun 18, 2007 06:17 PM
laself
May 9, 2007 11:04 AM
