Coolant Change 101
#46
Thermostat Removal
Perfect thanks. I saw the grooves and thought it might turn out but when I pushed down and made my attempt it wouldn't rotate. Your post gave me the confidence to try a bit harder. There was enough gunk in the grooves that going back and forth worked out the gunk and walla.
So, I guess this qualifies as the duh moment.
Thanks again, you saved me a ton of time and my boys thank you as now I will have time to sit down with them this evening and watch a John Wayne.
#48
Has anyone thought of adding this info to tech folder? I spent an hour searching for this info on using the VC-9. The bottle tells me to follow ford manual blaa, blaa.. Great info here on this post, just might be nice to find it easier...Thanks to all you guys, I will be doing the flush tomorrow. Just for precautionary purposes..
#49
#50
Question, wouldnt doing this increase the chances of you clogging your oil cooler? When the VC9 begins to break down the minerals in the block and cooling system? I would think you would want to do this before intalling a new oil cooler and EGT cooler, then add a coolant filter to keep the particles out of the coolers. I would think this would give you the most life out of your coolers.
#51
One other thing. When I do my flush this coming week, I'll be filling it with Rotella ELC. I figure why note use a coolant rated at 600k miles and supposedly doesn't form silicates when under extreme heat flashing! Hopefully it keeps the coolant system happy.
#52
#53
Ford states "105,000 miles on the initial change; subsequent changes every 45,000 miles. Check coolant strenght concentration every 6 months."
Also might the VC9 also be cleaning out your radiator too?
#54
From what I have been reading it's the Ford Gold low silicate formula that IS CAUSING the gel that clogs the oil coolers. When it gets super heated in the EGR cooler it causes silicate dropout (gel) to form and clog the coolers.
Just remember if it is not Ford Gold or Zerex GO5 you might run into coolant turning into jelly or jell-o in your system and then the flushing to get rid of it is a real treat.
#55
I just wanted to attach a link (below) to this thread, because I think the video is helpful:
https://www.ford-trucks.com/forums/9...ing-video.html
Also, on post #23 of the thread above rocky1074 mentions a chemical "RESTORE" that is advertised to dissolve silica gel.
I agree that the Ford Premium Gold coolant is TOO PRONE TO PROBLEMS!! Go with a Vat EC-1 rated ELC coolant!
#56
When I try to paste and go to site it does not go. Just goes back to your post on FTE.
Mike
#57
1) The use of distilled water as the "factory fill" when the motor/truck is made.
2) Marketing purposes to make maintenance costs appear less... hense, it is just past the 100,000 mile warrenty limit (go figure).
Ford knows that their own dealers do NOT use or have available distilled water in their shops, so this is why future service interval intervals are at shorter mileage intervals... and some only do a drain and refill and not a true 100% fluid flush.
I personally, do my own 100% distilled water flush and change/flush every 50,000 miles and never worry about it or check my nitite levels.... but that is me. I now have 180,000 trouble free miles on my truck, so I guess my "methodology" it is working???
#58
#59
Hit the "heart" at the upper right hand corner of a post (or posts) that are helpful and send the poster a thank you message (and give them "reputation points").
#60
I tried to send some to you and Beachbumcook, but was told I still needed to "spread the rep wealth".
