Coolant Change 101
Old Jan 9, 2011 | 02:59 PM
  #91
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Originally Posted by Tennesseepowerstroke
Beach,
My circumstances match yours with 2 exceptions. I don't have a coolant filter and have never sent oil samples for verification. With that said, my coolant was coal black after adding 2 qts of VC9, driving a few miles, and draining. I will add the VC9 to mine everytime I flush from now on. I plan on my truck lasting throughout my retirement years while pulling a fifth wheel. With no more miles than I pull with it that should not be a problem with proper maintenance. I know you are a fanatic about maintenance so you should "just do it".
Guess I need to verify when my next cooling system flush will be and plan on using VC-9 additive/cleaner and put it to the test. With 185,000 miles on my truck right now... it will not hurt to try it out and see what it does, if anything, after "X" many miles... depending on when I am due (too cold to do it now until the Spring or Summer I am assuming I will be due???)
Old Jan 9, 2011 | 03:24 PM
  #92
03-6L-X's Avatar
03-6L-X
Jeff:
When I did mine for the first time at 100,000 miles and used VC-9 (and installed the Coolant filter), I ended up attaching a garden hose to the hose at the bottom of the degass bottle that goes to the cab. I then added a hose to the heater valve on the passenger side of the engine (will try to find the TSB that describes the procedure and post). Ran this to a five gallon bucket and had an old pillowcase attached to the hose. With the two heaters turned wide open I let the water flow. The amount of "sand" I collected in the pillowcase was amazing. It was also the only way to flush the "brownish" liquid from my system. After that I just did the coolant flush as written without removing the T-stat.
Good luck will be waiting to hear your results.
Happy New Year.
Mike
Old Jan 9, 2011 | 04:00 PM
  #93
Beachbumcook
Got Diesel?
My coolant looked like new at 10,000 miles after the first change. After adding 2 qts of VC9 and driving a few miles, it came out coal black. After 12 flushes and 5000 more miles, the new coolant still looks good.
Got to thinking... what would make your system (using VC-9 cleaner) turn the fluid "coal black" as you describe above?
I have heard reports of "rust colors", sediment, flakes, sand, silcate drop out... but never "coal black" color fluid????
Wonder if the VC-9 cleaner reacted with the black radiator hoses in some way and removed some of the color or rubber on the inside of the hoses... then with enough flushing, it ran clear again???
What would be in your system to turn the fluid "coal black"... that you would not have seen inthe degas bottle to begin with....unless you had/have an oil leak or old oil residue in your cooling system that the VC-9 removed... but I would think that if it looked that bad during the flush, it would have looked that bad before the flush?
Ideas... anyone?????
Old Jan 9, 2011 | 04:13 PM
  #94
gearloose1's Avatar
gearloose1
Beach,
I have the greatest admiration and respect for your maintenance --- which far surpasses mine.
Having said that, let's take your "seat, see, hear" concept to its logical conclusion.
If you can get a borescope or a way to see inside the block and get the coolant's eye view of what is going on, what will you see / feel / hear?
Corrosion is insidious - it can lodge as a huge deposit inside that is resistant to a regular non VC9 flush.
So is scale. Even if you use distilled water, some minerals remain in water, and not just in the water, but from the coolant from which you use to fill the system.
So are a lot of bits of different chemicals, metals, silica sand (remaining from the casting process) that never leaves.
Add it all together, and there is enough stuff circulating around to basically create a mini chemical soup that as it is repeatedly heated, cooled, etc. create deposits.
Talk to a good stationary engineer, and you will find even in commercial boilers that use nothing but distilled water (eg on your average navy sub), it is common and normal for boilers to be disassembled and cleaned regularly.
Cleaned with a chemical cleaner that dissolves the deposits.
Insofar as the "black" test, I am not saying it is invalid, but I am saying that it is but one indication.
Even perfectly gold colored fluid can contain colorless dissolved solids --- which is what VC-9 is suppose to do.
If you want to see what accumulates in your boiler, see this:
www.awt.org/certification/quiz1.pdf
The Chemistry of Boiler Scales The primary constituent of boiler scales is magnetite (Fe
3O), which is formed as a result of the reaction of metallic iron with high-temperature steam. Other crystalline
4 materials, some shown in Table 1, may form the scale. Copper is present due to corrosion of the copper alloy, aluminum bronze feedwater condensers and preheaters, often because of oxygen ingress into these systems. Copper is transported through the steam cycle where it forms on the boiler internals. Other constituents shown in Table 1 are transported through the steam cycle and deposited on boiler internals either from contaminants contained in the boiler feedwater system or from use of outdated phosphate-based water treatment chemicals. In addition to these crystalline inorganic compounds, there may be organic residuals present in the scale.
Table 1: Compounds Found in Boiler Scales Compound Formula
Anhydrite CaSO
Aragonite CaCO
Brucite Mg(OH)
Copper Cu Calcite CaCO
Hematite Fe
Hydroxyapetite Ca
Magnetite Fe
Quartz SiO
Thenardite Na
Wollastonite CaSiO
As you can see, there is a lot there --- and probably more than VC9 can deal with by itself.
I applaud you for trying out VC9, which, given your rigorous maintenance, might not be needed every flush... but lets see what comes out first time after your 200,000 miles!
Old Jan 9, 2011 | 04:35 PM
  #95
Beachbumcook
Got Diesel?
Originally Posted by gearloose1
Beach,
Hey not fair.... you gave me a quiz for which I did not have the study materials for.... I FAILED and did not get one questions right!!!!!!
I will definately use VC-9 at my next coolant flush.... which I think may come later this summer due to mileage... and if past my self imposed 50,000 mile mark... will be when it warms back up outside!!! (will have to check my files to see when I last did it).
Old Jan 9, 2011 | 06:54 PM
  #96
Tennesseepowerstroke's Avatar
[QUOTE=Beachbumcook;9799030]Got to thinking... what would make your system (using VC-9 cleaner) turn the fluid "coal black" as you describe above?
I have seen pictures on threads of flushed water from a 6L that looked like mine. I don't have an explanation. Mine was rust colored after 6 flushes and cleared up from there. I backflushed the radiator with a garden hose. Did not remove the thermostat. If I had removed it, I am sure it would have not taken as many flushes with distilled water. I did pull the drivers side block plug between each flush.
I was hesitant to spend the money, but the VC9 made a believer out of me.
Old Jan 9, 2011 | 10:15 PM
  #97
epfire#233's Avatar
epfire#233
Excellent reading! Thank you to all for your insight.
Old Jan 9, 2011 | 10:38 PM
  #98
epfire#233's Avatar
epfire#233
This may be a silly question, but where and how do you discard all of the used coolant?
Old Jan 9, 2011 | 11:24 PM
  #99
Piolet's Avatar
Piolet
Some folks here who are part of a regular water service pour it down the drain .... not the storm drain which can feed into rivers and streams. The folks who've mentioned that they do it this way have confirmed with their local service that it can treat the stuff in coolant.
I live with a septic system and I get my drinking water from a well on my property. So I didn't want to pour it down my drain or on my land.
I called my local Ford dealer and they'll take it for $1 per gallon.
One member posted that their local transfer station said they'd take it, but then weren't too happy when he showed up with 20gal after doing a flush
A local shop may take it from you for nothing or a small fee.
Old Jan 10, 2011 | 12:02 AM
  #100
Beachbumcook
Got Diesel?
Side of road next to my 2 acre lot on my grass. fluid and water drains into my grass and soaks in. It kills it... but it grows back. I move the truck back a foot each time or so and use a "crawler" so I do not get wet laying on the ground.
After the first dump or two... the coolant soaks in and then dillutes... after it snows and rains... it is really dilluted. Can't be any worse than a truck wreck or chemical spill anywhere else along the road or highway (is how I justify it).
Screw it... private property... as far as I am concerned.
Old Jan 10, 2011 | 09:27 AM
  #101
bpounds's Avatar
bpounds
I put mine down the sink to the sewer system. Actually, just the first couple of flushes while it is still strong, then after that it is mostly water anyway and I pour it out on a gravel garden area. Hasn't killed the Ivy yet, but I keep hoping.
Old Jan 10, 2011 | 09:56 AM
  #102
gearloose1's Avatar
gearloose1
It is pretty good with Vodka or Moonshine.
Old Jan 10, 2011 | 10:04 AM
  #103
Beachbumcook
Got Diesel?
Used coolant is used in baby formula in China, dog food and is an ingredient in meth... so I was selling to a local drug crazed recycler.... I thought I was doing my part by being a Tree-Hugging" enviromentalist recycling kind of guy!!!!
I hugged a tree once.... and I killed it
Sorry guys.... I am a diesel driving, black smoke generating, gun toting, conceal-carrying, God fearing, do what I want, leave me alone and I will leave you a lone kind of of guy. I am also a buy me a beer I will also buy you a beer kind of guy as well.
Old Jan 10, 2011 | 10:49 AM
  #104
07Dually's Avatar
07Dually
Sorry guys.... I am a diesel driving, black smoke generating, gun toting, conceal-carrying, God fearing, do what I want, leave me alone and I will leave you a lone kind of of guy. I am also a buy me a beer I will also buy you a beer kind of guy as well. [/QUOTE]
No reason to be sorry about that!
Old Jan 10, 2011 | 01:01 PM
  #105
Beachbumcook
Got Diesel?
No reason to be sorry about that![/QUOTE]
I know... only in case someone gets their panties in a wad about dropping the used coolant on the ground. I am sure there are a few Liberals here on the forums.... and I just wanted to make sure they know who they may be messing with....
