Coolant Change 101
Old Nov 2, 2011 | 06:03 AM
  #136
stang70's Avatar
stang70
Originally Posted by bismic
If you use VC9, you need to get it up to temperature (ie leave thermostat in or block the air flow). If you simply flush, then you don't need the thermostat.
Some people have plugged their new oil cooler with what was freed up w/ an agressive chemical flush. Not saying you would or you wouldn't, just reporting what has happened.
I agree w/ Tennesseepowerstroke that it is not good to drive for very long w/ straight distilled water. It is corrosive when the temperature elevates. Also, I would not be too crazy about a dealership using tap water.
The local Ford dealer quoted me a price of $168 for cooling system service. I paid a $115 for 4 gallons of gold coolant and 2 quarts of VC9 and at todays labor rates tells me they are skipping steps somewhere so that is why I decided to do it myself. Plus the fact that I was afraid they would use tap water vice distilled water!!
Old Nov 2, 2011 | 08:43 AM
  #137
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Originally Posted by homeschoolin
Thanks BBC. I read the whole thread leading up to my questions. I saw earlier that you were saying you might use the VC9 at your next flush interval. Are you doing that just to experiment or have you now changed your mind on the necessity of using VC9? Earlier in the thread you had said you were happy with a 50K flush interval using just the distilled water. Then the VC9 fans seemed to change your mind. I am not implying you are a flip-flopper, just curious where you stand now. My coolant system has never been opened since the truck was new, as you said was the case with yours.
You answered a bunch of my questions in your response. I am glad to hear I can just let the drained fluids run out without having to try to catch and manage all of that fluid. Also glad to hear that I can just tool around for 5 or 10 miles to reach the proper temp to open the thermostat for each flush cycle. I live in Phoenix so we are starting with warmer ambient temps than most people in the US.
We have pavestones on our driveway and desert landscaping, so no grass to worry about.
If I skip the VC9, will what comes out of the radiator be likely to stain a pavestone driveway?
My driveway has a slope and a flat pad at the top in front of the garage doors. Can I get any benefit in draining fluid by parking the truck a certain way on the sloped part of the driveway?
I like to do things for myself when I know I can do it right and this job seems to be within my limited skill set (I have been doing oil changes and fuel filters since I bought the truck). I work from home, so I have the time, especially if I only have to drive 5 to 10 miles per flush interval.
In reply to your questions.
My system is clean and has always been flushed every 50,000 miles... and I never worry about it (testing it for nitrate levels and such). I also have a dieselsite.com coolant filter installed since 50,000 miles or so. The pictures in the 6.0L section of the dieselsite.com site are mine that I sent them after being so impressed with their system years back!!!
I did NOT use the VC9 cleaner as many also advised me to "Do not disturb a turd that does stink"... meaning my truck is running fine and my coolant in the degas bottle is clean and no oil or such is present... and my oil cooler and EGR cooler all seem to being well. Why spend the money on VC9 and extra water (was my rational for NOT using it last month when I flushed my system).
The lower radiator hose is on the right side of the truck, so I always park my truck in my grass so the right side is slightly lower than the left side as to help drain the radiator and lower radiator hose/motor fully (water runs downhill you know - he, he).
As far as will the coolant stain... I have no idea... it will make your driveway slippery/slick if not cleaned up and flushed when down... I would drain it into your gravel or rocks (not not on your driveway). Have a piece of cardboard to lay on when disconnecting the lower hose... but be prepared to move quick when releasing the hose (you will get a little wet)!!
I also drive my truck to warm it up before the first drain... this makes everything drain and flow better and maybe suspends any sediment? As well, on the next few drains, the motor is already warm and reduces the "drive time" for the second draining.
If you do not have a coolant filter, now is the time to add one. Check out dieselsite.com for one that I highly recommend. Just buy the ball valves which is an accessory to make changing the filter easier and less messy.
FYI - open the degas bottle after each "driving trip" to release pressure before dropping the lowe radiator hose.
Good luck,
Old Nov 5, 2011 | 11:38 AM
  #138
stang70's Avatar
stang70
Ok did my coolant flush yesterday per BBC instructions Very time consuming not taking the thermostat out After the 1ST flush with the vc9 the water was a little rusty but not as bad as I thought it would be. After the 4TH flush the water was perfectly clear Now the problem after I put the 3.5 gal of gold coolant in I could only get in approx 1 gal of distilled water in. Can anybody explain this to me?? I double checked my owners manual and it clearly states that my truck has 27.5 quart capability. Unless their is a blockage some place I know it was completely drained cuz I drop the lower hose and left it about 30 min
Old Nov 5, 2011 | 11:47 AM
  #139
bpounds's Avatar
bpounds
Perfectly normal. The reason is because you still had around 2.5 gallons of distilled water in the system. It is impossible to completely drain the system with the engine in the truck. This is why you used distilled water throughout the flush process, because that water is going to still be in the block when you add your coolant.
Good job! Have a couple beers.
Old Nov 5, 2011 | 01:29 PM
  #140
Beachbumcook
Got Diesel?
Normal... Water stays in block... Your are never draining 100% of the water with just dropping the hose.
You can use between 3.5 - 3.7 gallons.
If you have a coolant filter add an extra pint of coolant over the 3.5 gallons
Old Nov 5, 2011 | 01:39 PM
  #141
stang70's Avatar
stang70
DUH!!!! I should have known that!! Thanks bpounds and BBC for the reply!! I think I'm getting dummer in my old age!! Think I will have them beers maybe get the blood circulating to my brain again
Old Nov 12, 2011 | 09:00 PM
  #142
homeschoolin's Avatar
homeschoolin
I did my coolant change today. I bought 18 gallons of distilled water at Walmart for 83 cents each and 4 gallons of Zerex G-05 at O'Reilly's for $17 each. I did the draining through the radiator stopcock instead of by the lower radiator hose and I did not remove the thermostat nor did I do any chemical flushing with VC-9, Restore, Simple Green or any of the other things I have seen mentioned.
The first drain came out yellow with no signs of any sediment or other debris. Each successive drain was a bit less yellow. By the fourth or fifth drain cycle the water was substantially clear with just a hint of coolant. I stopped there with the draining and refilling.
I used the slope of my driveway (front of truck pointed downhill, of course) for my final drain and got out about a half gallon more fluid than the earlier drains which were done on the flat part of my driveway.
Added the 3.5 gallons of G-05, strarted up and topped off with distilled water to the min mark. I will keep an eye on the level when I go for my next drive.
After my first drain, I could see some sludge/sediment stuck to the contours of the degas bottle. I took off the degas bottle so that I could try to flush it clean. I used the flexible plastic tool below attached to my garden hose to try and blast loose the sludge.
Camco 11691 Water Heater Flushing Tool Camper Trailer Rv
I got most of the sludge out but I was surprised how well stuck onto the contours of the degas bottle the sludge was. If I could not get a direct stream of pressurized water on the sludge then it was not coming out. I can see how an oil cooler would clog if this sort of stuff was floating around and looking for a place to land and stick. I can only hope that I don't have too many other similar deposits lodged elsewhere in my coolant system.
I decided to pass on the coolant filter for the moment.
Thanks for all of the advice on this procedure.
Old Nov 12, 2011 | 11:35 PM
  #143
Tennesseepowerstroke's Avatar
Rest assured you have them elsewhere. They did not decide to only deposit themselves in the degas bottle. This is why you need the VC-9. It is pay me now or pay me later.
Old Nov 13, 2011 | 10:29 AM
  #144
homeschoolin
What you say makes sense. The only issue with the VC-9 is knowing to what extent those deposits are truly loosened and/or dissolved and then how well they suspend and flow out with the rest draining fluid as opposed to simply lodging somewhere else (possibly worse). I don't think there is any way to know the answer to which course is best.
Since we use the truck almost exclusively for towing our fifth-wheel which usually amounts to anywhere from 5K to 9K miles per year (54K total now on our 06 placed in service in late 05), I am hopeful we can get the 150K and up that some here are reporting on their OEM oil coolers with only doing the distilled water flushing. That is at least another 10 years of towing for us. Fingers are crossed that I guessed right as to how to treat the cooling system.
Old Nov 13, 2011 | 10:43 AM
  #145
bpounds's Avatar
bpounds
I'm with you, homeschoolin. The VC-9 should not be used when you have good heat transfer in your oil cooler. Only use it when there is already restricted flow.
Using VC-9 is not on the Ford maintenance schedule. But coolant flushes are on the schedule. Not that the Ford schedule is perfect, it obviously is not.
BTW, a new degas bottle and cap is not very expensive. And you get nice clear plastic for a while. I wouldn't spend too much time trying to clean one.
Old Nov 13, 2011 | 02:14 PM
  #146
There isn't any way to know but i would bet with the lower miles on your truck that it would clean it up without any harm. My truck has low miles also and i plan on using the VC9 every year or two to keep it clean. That is a lot cheaper than an oil cooler. I guess we all have do what we think is best for our trucks. I am curious as to what will come out the next time I use the VC9.
Old Nov 13, 2011 | 04:06 PM
  #147
archtaan's Avatar
archtaan
Thanks for the tips, I had to replace an oil cooler last year and plan on swapping out the coolant. I already added a coolant filter, probably too late but who knows.
Old Nov 13, 2011 | 05:28 PM
  #148
homeschoolin
If we both keep our trucks then it will be interesting to compare notes as our trucks age with you doing the VC-9 flushing and me doing distilled water only flushing. A sample of two is too small to be of any scientific value, but interesting nonetheless.
My general philosophy is: "when in doubt of the benefit(s), keep your money in your pocket" (unless a safety issue is involved).
Old Nov 22, 2011 | 09:53 PM
  #149
foevrluvinit's Avatar
foevrluvinit
Thanks to all of you for the info. I feel like I've been reading this one thread all night and now I have another project to do! This is next on my list. After the brake fix on the rear and working on the AC.
Old Dec 1, 2011 | 10:34 AM
  #150
WWBeast's Avatar
WWBeast
Ya i think I will not be using VC-9 either, my spread between oil temp and coolant temps are like 0-4 driving in town and almost always stays at 6 differential driving on the highway. Ill be doing just the flush with distilled water, im afraid if i use VC-9 it may clog my cooler, i could be totally wrong but obviously my coolant system is doing ok so why take a chance and make it worse...if the spread increases then ill try vc-9. just my thoughts great read though, makes a boring day at work go by quicker.
