Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
New Here
Old Dec 7, 2009 | 10:53 AM
  #136
preppypyro's Avatar
preppypyro
Sounds like a kickass meter, should be no problems there at all. I assume its pretty damn cold up there right now too, hard to do testing in this kind of weather outside.
Old Dec 7, 2009 | 12:18 PM
  #137
Northern Gal's Avatar
Northern Gal
Yup, the meter is a good one, guess you get what you pay for.
Cold isn't the word for it, -29 & with wind chill factored in, it's -40! Haven't even gone out side yet today, going to wait till it warms up - next spring! LOL Got the poor truck plugged in, sure hope it starts later, as I need to go to town. It sat all day yesterday at -24, not plugged in, and it started fairly easily. Was at a friend's place and no where to plug it in, so was taking my chances.
Old Dec 7, 2009 | 02:43 PM
  #138
Fomoko1's Avatar
Fomoko1
Not much better here either, minus 22 and with the wind chill it`s minus 29.
Old Dec 7, 2009 | 05:28 PM
  #139
66gpw's Avatar
66gpw
I been starting to lean towards that your battery maybe hooped. It sounds just like what has happen to me in the past. Bad battery plates in the battery. They make contact when cold and later when you shut it off warmed up . Your have no or nil for power. The vehicle is hard to turn except with a boost. If you can find another battery to use from a friend. If it stays charged and not dies then it is a battery.
Old Dec 7, 2009 | 05:39 PM
  #140
Northern Gal
Those beaches lined with palm trees and bikinis starting to look good eh?
Old Dec 7, 2009 | 05:49 PM
  #141
Northern Gal
I don't know. The only time I had to boost it was last Thurs. when it sat for 20 mins. after running for an hour, then I ran it for about 15 - 20 mins then had to shut it off to refuel,but it started easily again. Today was a little different due to the cold temp. it turned over, then died, but started again on the next try.
I've checked around for a spare battery to swap it with but no luck yet,andI amdefinitely not going to spend $100 to $160 to get a load test done on it!
Old Dec 7, 2009 | 06:33 PM
  #142
Fomoko1's Avatar
Fomoko1
You read my mind.
Old Dec 7, 2009 | 06:37 PM
  #143
Northern Gal
You read my mind.
and am I reading it right when it's not the palm trees, and sand that interest you much.....? lol
Old Dec 7, 2009 | 06:48 PM
  #144
Fomoko1's Avatar
Fomoko1
Not just the palm trees and sand of course, the warmer temps too..........Huh!
Old Dec 7, 2009 | 06:51 PM
  #145
FORD RANGER's Avatar
FORD RANGER
yeah put that vision in my brain..
Old Dec 7, 2009 | 07:02 PM
  #146
preppypyro's Avatar
preppypyro
Bikinis almost never look bad!
Could be the battery, but MOST of the times when the batteries go, they will be really weak and not hold a 12v reading at all.
I guess not all the times though, and I still dont know if thats the problem. My truck does the same thing, and its done it with a few different batteries, including the last new one which i did get load tested and it checked out fine (so the coop in melfort said)
Old Dec 7, 2009 | 07:04 PM
  #147
Northern Gal
Ya, and I'm the flying nun......puuleeeze, don't make me laugh so hard!
Old Dec 7, 2009 | 07:05 PM
  #148
Northern Gal
So Sorry, lol
Old Dec 7, 2009 | 07:10 PM
  #149
Northern Gal
Guess it's been a while since you've been to the beach.
Got good readings from mine
I'm still leaning towards a loose ground or the heater fan, but just can't seem to follow the wiring, as no diagram available.
Old Dec 7, 2009 | 07:14 PM
  #150
Northern Gal
Sorry, that didn't post right????
Tried to seperate my responses to the individual lines in one post, oh well, you all get the drift.
