Cleaning the CDR
Old Oct 24, 2009 | 09:39 AM
johnboggs21's Avatar
johnboggs21
Cleaning the CDR
How do you guys clean the CDR in your trucks? I figured it wouldnt hurt to pull mine off and clean it, but i dont want to mess it up and end up having to get another one.
Old Oct 24, 2009 | 09:43 AM
Mat J's Avatar
Mat J
just keep flushing it out with gas and let it air dry, dont use compressed air, due this every oil change.
Old Oct 24, 2009 | 07:36 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Let it soak in Gasoline for a few hours, ones in a while during that time take it out shake it, and put it back in the Gas. After a couple of hours take it out, let dry on it's own (DO NOT blow compressed air into it) and re-install.
Old Oct 24, 2009 | 08:04 PM
The_Josh_Bear's Avatar
The_Josh_Bear
Red face
Newb question:
What's a CDR?
Old Oct 24, 2009 | 08:42 PM
IDIDieselJohn
Originally Posted by The_Josh_Bear
Newb question:
What's a CDR?
This:
and don't feel like a nood, I had to ask that same question at one time
Old Oct 24, 2009 | 10:10 PM
Happyreefer's Avatar
Happyreefer
CDR= Crankcase depression regulator. Allows engine gases to return to the air intake while keeping engine oil in the engine.
Also, a Diesel engine version of the PCV valve on a gasoline engine.
Old Oct 25, 2009 | 09:28 AM
Dave Sponaugle's Avatar
Dave Sponaugle
John I saved your picture since it has a perspective that us F series drivers never get to see.
Hope you don't mind if I point out a few more things and use it to show where the oil pressure sender and I can even see the plug where the 6.9 glow plug controller would be located.
Old Oct 25, 2009 | 02:39 PM
IDIDieselJohn
No Problem at all Dave, if anyone else wants it to show differrent things off of it that's perfect! That's what I wanted to do my self anyways lol, I got a couple more pics of the engine at different angles to.
Old Oct 25, 2009 | 02:48 PM
IDIDieselJohn
Also if you want the original one without the CDR thing on it, just let me know.
Old Oct 25, 2009 | 08:43 PM
Dave Sponaugle
The CDR pointed out is a good thing, we never see it from that angle in our trucks.
Old Oct 26, 2009 | 02:35 PM
Red Cobra's Avatar
Red Cobra
on a 94 turbo diesel its on the valve cover is it not? does anyone have a part #? please and thanx
Old Oct 26, 2009 | 07:46 PM
Dave Sponaugle
Yes that is correct.
I have seen both the Ford and International numbers posted before, but I never saved them.
VT tree grower
Jan 3, 2017 09:58 AM
Ethan Robinson
Oct 4, 2016 08:52 PM
rterril02
Oct 3, 2016 03:44 PM
MtTheJeffro
15
Oct 11, 2015 04:56 PM
bronco460
Sep 2, 2003 10:36 PM
