Aim/DJM lowering kit thread
Old Jan 11, 2015 | 01:19 PM
  #151
nevaplayedk9's Avatar
nevaplayedk9
Originally Posted by HIO Silver
Easiest: DJM lowering beams and: DJM spring hangers & shackles; Or a rear hanger flip with a couple of leaves removed; Or, Airbagit axle flip or Fatman Fabrications axle flip. C-notch highly advised.
Medium "Difficulty": Front - CV subframe swap for the front. Rear - One of the methods stated above for the rear or an MN12 (Cougar/T-bird) IRS subframe swap.
Very Involved: Mustang II-style IFS for the front (Heidt's, Fatman Fab, etc.) and a three-link, four-link, or ladder bar rear suspension conversion.
Mix n match at your discretion.
I think im going this route first.......any drawbacks?
Old Jan 11, 2015 | 02:01 PM
  #152
BobbyFord's Avatar
BobbyFord
Measure pinion angle prior to suspension mods.
Old Jan 11, 2015 | 02:04 PM
  #153
37 Ford guy's Avatar
37 Ford guy
also, if you're removing rear leafs you will reduce your load capacity. May not matter if you no longer use it as a truck.
Old Jan 11, 2015 | 05:26 PM
  #154
HIO Silver's Avatar
HIO Silver
2x... a full flip is easier to do on a shortbed than a longbed with a two-piece driveshaft. I did it on my 70 and resulted with 10° of nose up angle... ended up doing an axle flip instead. A shortbed will end up with 4°-6° of nose up which can easily corrected with shims.
Old Jan 11, 2015 | 06:24 PM
  #155
williamwilliam's Avatar
williamwilliam
I havent been on here much as of late, but I see this thread is still going. LOL.
If you ever plan on putting your truck back to original, go with the AIM/DJM setup. If you dont give a rats a$$ about putting it back if you ever need to, do the other mods. My truck is still going with this setup going on 11 years now and no problems. To each their own.
Old Jan 14, 2015 | 09:59 AM
  #156
marktw's Avatar
marktw
What do you all think about chasis tech (aibagit) I beams has anyone used them
Old Jan 14, 2015 | 10:32 AM
  #157
BobbyFord's Avatar
BobbyFord
I've only heard bad things about the AIM beams.
Old Jan 15, 2015 | 01:52 PM
  #158
williamwilliam
AIM is what I have under my truck.
Old Jan 15, 2015 | 01:56 PM
  #159
BobbyFord's Avatar
BobbyFord
I've heard fitment horror stories and customer service horror stories.
Old Jan 15, 2015 | 06:30 PM
  #160
JEFFFAFA's Avatar
JEFFFAFA
Seems to me I remember reading about a year ago someone chimed in and said something must have happened at AIM. Saying used to be good product but now gone to Heck.
Old Jan 15, 2015 | 06:55 PM
  #161
crazed87bronco's Avatar
crazed87bronco
^ I was following along for awhile on the whole AIM DJM debate and problem fitment thread. If I reminder right a fellow member tried the AIM beams and had one problem after another with kingpins and fitment or something like that went back n forth with the company trying new beams and he ended up going to the AIM facility and meeting with the big wigs and found out there jig was way off. Therefore making the beams junk. I think the owner wasn't to worried about fixing it right away. Anyone else recall this?
Old Jan 15, 2015 | 07:29 PM
  #162
HIO Silver's Avatar
HIO Silver
Originally Posted by crazed87bronco
^ I was following along for awhile on the whole AIM vs DJM debate and problem fitment thread. If I reminder right a fellow member tried the AIM beams and had one problem after another with kingpins and fitment or something like that went back n forth with the company trying new beams and he ended up going to the AIM facility and meeting with the big wigs and found out there jig was way off. Therefore making the beams junk. I think the owner wasn't to worried about fixing it right away. Anyone else recall this?
Yep.. I recall that... most if it. I don't recall the part about the owner not being too worried.
Maybe it's posted earlier in this thread? I'm stuck at work and can't like really look it up at this time...I'm on a mental break and FTEing it with you guys for a bit...
FTE is my "mental floss".
Old Jan 15, 2015 | 08:16 PM
  #163
dman2008's Avatar
dman2008
I think it was this one.
https://www.ford-trucks.com/forums/1...t-my-luck.html
D
Old Jan 15, 2015 | 09:43 PM
  #164
crazed87bronco
^ that would be the thread. I thought there was some kind of dispute over making them right. Just didn't turn out even after a good set of stock ones was taken in to help produce good ones.
Old Jan 16, 2015 | 11:34 AM
  #165
williamwilliam
I also said they must have changed something because I had/have zero problems with my AIM setup. Again, I bought mine back in 2004 so maybe they did change something, although I dont know why they did.
