okay im having serious issues with my 96 in my sig. Recently my ABS light has been coming on intermitently and sometimes the speedo fluctuates or quits working, shutting the truck off and restarting made the ABS light go off and everything go back to normal. Today the ABS came on and stayed on and the speedo won't work at all, shutting the truck off and restarting no longer solves anything. cleaned RABS sensor and still no improvement..... any other quick or cheap checks before i buy a new POSM and RABS sensor??? Thanks
my friend had a similar problem on a 99f250, i think it might have ended up being wheel sensors? not sure worth a look, i think that;s what it was. good luck
Tonight i worked for about five hours checking continuity from the RABS sensor to the RABS data plug and found that the last three feet of the red w/ pink tracer wire at the RABS sensor was corroded. Spliced in a new wire and have been good to go so far. Thanks for all your help
