Sponsored by: Real Truck
1999 abs problem
Old Apr 16, 2015 | 12:19 PM
harback's Avatar
harback
1999 abs problem
I have a abs light on, no speedo until 30mph, cruise works, overhead display went dim and the overdrive light flashes while moving until the speedo kicks in. I pulled the abs sensor rabs only and ohmed out at 2.7 cleaned and reinstalled with no change in the problem I also disconnected the battery's and reconnected. What should the sensor ohm out to? What can I check next?
Thank you for your help.
I drive the truck daily.
Old Apr 16, 2015 | 12:34 PM
harback's Avatar
harback
It is a early 1999 f350 lariat 4dr 4x4 7.3 auto 130k and 11 years of proud ownership.
Treeman75
Sep 8, 2011 02:10 PM
Big Greenie
Oct 6, 2010 01:27 PM
dpc
Apr 30, 2007 11:05 AM
moneypitt
Apr 22, 2005 06:05 AM
mgdhunter
Oct 1, 2003 01:01 PM
