Rabs abs speed sensor
Old May 18, 2009 | 09:38 PM
gthbryce's Avatar
gthbryce
Rabs abs speed sensor... I replaced the abs sensor in my axle today thinking it would fix my amber rear antilock brake light from staying lit. After starting it up turning it off after a couple minutes and turning it back on as soon as it cranked over the light goes off for about a second then comes back on and stays lit. What else could be triggering it to stay on?
Old May 19, 2009 | 03:37 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have collected some posts trying to solve this problem.
Can't get them now, but given a chance when I get back I'll search my subscribed threads for you.
You might need to bleed the RABS valve inside the frame rail beneath the driver.
There is a wire you can ground up above the footwell for a diagnostic self-test. (IIRC it's black and orange)
But I got no flashes, soooo finally gave up and have been staring at that stupid light for years.
Old May 19, 2009 | 04:45 AM
EPNCSU2006's Avatar
EPNCSU2006
Check the wiring at the master cylinder. I had a nagging RABS light that went away when I replaced the master cylinder. Apparently there was just a bad connection at the float switch and taking the wiring on and off made enough contact to complete the circuit. I could never get the RABS light to flash any codes when grounding the black/orange wire either.
Old May 19, 2009 | 12:24 PM
gthbryce's Avatar
gthbryce
ok I'll try both of your guys suggestions, thanks
Da_Lariat_Chariot
Oct 7, 2016 01:09 PM
rlvbronco
1978 - 1996 Big Bronco
Sep 14, 2016 05:12 PM
85F350IDI
Mar 3, 2016 04:27 PM
BluegrassPicker
15
Oct 10, 2011 10:17 PM
FordPower2000
Jun 4, 2003 12:09 PM
