front Spring hangers
Old Sep 22, 2009 | 05:34 PM
  #151
ChaseTruck754's Avatar
ChaseTruck754
Looking food Dave. You 3rd pics reminded me of something though...
Just a hint for you MIG welders out there. A little "Pam" cooking spray on the area surrounding where you are going to weld will keep the spatter from sticking.
Old Sep 22, 2009 | 06:02 PM
  #152
Damstr8's Avatar
Damstr8
Yes Pam High Heat is always my choice. Found alot of it at Big Lots and bought a case. At work I use Spatter Spatter. But at $10 a can Pam at 97 cents is fine with me.
Old Sep 22, 2009 | 06:06 PM
  #153
ChaseTruck754
Yeah the welding industry has a few different sprays - but like you said they are $10 or so a can and Pam is like $1 and does the same thing
Old Sep 22, 2009 | 06:45 PM
  #154
crazyredneckanyhow's Avatar
crazyredneckanyhow
Hmmm i used shielding gas. still need anti spatter?
Old Sep 22, 2009 | 06:47 PM
  #155
ChaseTruck754
yes. Look at pics 1 and 3
Old Sep 22, 2009 | 07:25 PM
  #156
Damstr8's Avatar
Damstr8
Shielding gas only helps the flame and flow, and not to get porosity. Any mig will cause spatter as you are forcing wire into the weld. The Pam or Spatter Spray won't let the spatter fuse to the metal. Using Pam or Spatter Spray will leave you just wiping away the spatter beads with a towel.
Tig welding leaves no spatter as you the welder are feeding the rod by hand and not forcing it into the weld. At least if you do it right.
Old Sep 22, 2009 | 07:31 PM
  #157
crazyredneckanyhow
Yeah. If i did stuff alot like Steve id have a TIG. Just cant justify the price for what i do.
Old Sep 23, 2009 | 01:22 PM
  #158
ChaseTruck754
Keep your eyes peeled on craigslist, etc. I've sole complete, older TIG machines for as little as $400. That one was an old airco that needed a bottle and that's pretty much it.
I've got like $1200 in my TIG when done. While not cheap - it's not a ton compared to the $4k or whatever they get for the new machines now. And for how much I use it...
Speaking of using it...
I started the shackles last night. They technically can qualify as "front spring hangers" and they are needed due to lowering the front leaf mounts, so I'll post the build here (as well as in my build thread of course)
Starting of the shackles
Ends turned down and tubes cut and partially notched
Tacked and clamped to the table to prevent warping
Welding started
Old Sep 23, 2009 | 06:25 PM
  #159
crazyredneckanyhow
I need some of those 2" longer than stock.
Old Sep 24, 2009 | 09:04 PM
  #160
crazyredneckanyhow
Heres a general look from the front. And a starter idea for a side brace. Opinions?
Old Sep 24, 2009 | 09:51 PM
  #161
71hightoy's Avatar
71hightoy
any body wana sell me a welder?
I think it would be nice if the starter of this thread (me) made some progress..
for what its worth ive been staying busy out back of the truck.. but it pisses me off seeing it just sit there..... errrrrr
Old Sep 25, 2009 | 12:53 AM
  #162
ChaseTruck754
Looks good Dave. Plate the front too...
71hightoy - sorry about the lack of welder. I'd let you borrow my MIG - but you're kinda far away.
As for me - a bit more done on the supercab and a bit more on the shackles for the crew.
Finished the first one
Repeated the exact same process for the second one - so no need to take more pics.
Just in case though I took this one - so you can see I have 2 done
Old Sep 25, 2009 | 03:28 PM
  #163
scottfreeman's Avatar
scottfreeman
Thumbs up I like
Those tube shackles are awesome! I think I may need to modify the ones I built with some half tube on them. I don't know if I can cut that straight though.
Old Sep 26, 2009 | 06:42 AM
  #164
teds74ford's Avatar
teds74ford
All you need is an angle grinder
Old Sep 27, 2009 | 12:14 AM
  #165
ChaseTruck754
Yup - that will work. I did mine with the port-a-band though. LOVE that thing
