North Dakota Chapter Join Chapter, Leader: hav24wheel
ND Chat and Other Meaniful Posts
Old May 14, 2010 | 04:22 PM
  #856
hav24wheel's Avatar
hav24wheel
Yep, she's a good one. Glad she puts up with me.
On a side note, I'm sellin my 33s. I'm going to use my 15x10 wheels on my wifes IH wheeler,and going to get some 16x10s for my DD, as 16 inch tires are a lot cheaper.
Old May 14, 2010 | 05:06 PM
  #857
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
me too, I have one that has put up with me for the last 19 years, and it took twice to find this one, she's a keeper.
Old May 14, 2010 | 05:23 PM
  #858
GLR's Avatar
GLR
Any lady that will put up with you guys and any FTE'ers is def. a keeper.
Old May 14, 2010 | 07:20 PM
  #859
sddesigns's Avatar
sddesigns
FTE Emeritus
Thanks George!
Old May 15, 2010 | 07:28 AM
  #860
sddesigns's Avatar
sddesigns
FTE Emeritus
Good Morning ND.....
Old May 15, 2010 | 10:22 AM
  #861
l67cooled's Avatar
l67cooled
Good morning Steve! Having a good weekend so far?
Old May 15, 2010 | 11:17 AM
  #862
sddesigns's Avatar
sddesigns
FTE Emeritus
It has been busy getting ready for my oldest daughters B-day dinner! How about you?
Old May 16, 2010 | 08:44 AM
  #863
sddesigns's Avatar
sddesigns
FTE Emeritus
Good Sunday Morning ND!....
Old May 20, 2010 | 09:55 AM
  #864
l67cooled's Avatar
l67cooled
Hello ND. Kinda slow around here again.
Dave I have a question about gears. I've been considering changing out my 3.55's for 4.56's and hopefully a locker for the rear. Here's where I've been looking Ford 8.8 Gears -
My questions is whats the difference between the superior and yukon gear set? Do I need anything else besides the ring and pinion set for the gear change? I noticed some say reversed, whats this used for?
Where can you find a reasonable priced locker? I want to start some repairs on this truck and figured it would be a good time to switch out a few things. Any other recommendations of what I should do are greatly appreciated.
Thanks
Ryan
Old May 20, 2010 | 10:33 AM
  #865
hav24wheel's Avatar
hav24wheel
Well, first, the 4x4groupbuy site doesn't work on my Blackberry, so I casnt look at it ast the moment, second, I have found good prices on broncograveyard.com for a wide variety of parts. Infact, that's where I got the ones for my DD. I have had hit and miss luck with Yukon gears, rumor has it that they are reboxed gears from other manufactures. So, if possible, stay away from them because you never know what you are getting.
When you do the rear gears, I would recommend a major rebuild kit for it too, I think I got mine for $108 includes all bearings, (wheel, carrier, and pinion bearings, and wheel, and pinion seals, along with a diff cover gasket and shims for the carrier). As for a cheap locker, the aussie locker is a good one to get, my little brother had one before I got mine and we both have had good luck with them. You will need a hardened crosspin for it, and wilklk have to grind a tooth or two down a bit on the ring gear to get it in there(not a big deal at all).
As for the reverse rotation, that is a high pinion axle, the front. They have been used in the front of Ford half tons sense around 76. You can get away with just a gear set for the front axle. (If your careful removing bearings) when I put the gears in mine, I think it cost around $500. I used USA standard gears in one end and Motives in the other. They where the cheapest gears I could find, and they are quality stuff. When I get to a computer later today I'll post up some links and some more info.
Old May 20, 2010 | 10:52 AM
  #866
l67cooled's Avatar
l67cooled
Much appreciated Dave! And thanks in advance for posting links, I'm sure it will help a ton. You know how I am with this junk, all pretty new to me. Is there any special tools needed in the installation? I know its something I want/ need to do but I just don't want to order all the parts, tear it all apart and realize its over my head or ends up taking weeks because of lack or tools or knowledge. I've done this way to many times. lol
Old May 20, 2010 | 11:09 AM
  #867
hav24wheel's Avatar
hav24wheel
Umm, a slide hammer to get the wheel bearings out. Other than that a air hammer and a micrometer, and a dial indicator is nice but not necessary if u know what ur doing. And a BFH. Lol. I've done my fair share of gear installs, so its a cake walk for me.
Easy to learn.
8.8 rebuild kit.
8.8 inch Rear Axle Super Rebuild Kit
8.8 gears. The notched crosspin is not needed if installing a Aussie or Powertrax Locker.
Ford 8.8" Motive Gear Ring and Pinion, 4.56 ratio
Here are the front D44 gears.
USA Standard Gear Ring And Pinion, Reverse Rotation 4.56
But, I forgot to mention this earlier, you NEED a different carrier for the front in order to run the 4.56s. This one is cheap, just have to swap ur spider gears and crosspin into it. They do have a loaded one too if yours are shot.
D44 Open carrier case only, 3.93 - 5.38
Old May 20, 2010 | 11:53 AM
  #868
l67cooled's Avatar
l67cooled
lol , well I only have the air hammer out of them tools. But I'm sure I can somehow locate what I need, always do but takes time.
Do you know of a reasonable place to purchase a aussie locker? I can't seem to find them at bronco grave yard?
I guess what I'd be planning on doing is:
All 5 u joints on the front
all 4 ball joints front
Might replace radius arm bushings
All new wheel bearings front
New tie rods and flip the tie rods
new super flex front coils ( maybe )
4.56 front
d44 carrier
4.56 rear
rear rebuild kit
And some sort of locker for the rear.
can you think of anything else to do since I'll be in there? I really don't want to tear into it again unless it breaks. haha
Old May 20, 2010 | 11:59 AM
  #869
hav24wheel's Avatar
hav24wheel
I think right from the Aussie locker web site. I don't know where mine casme from. So..... Looks like a good list to me.
Old May 20, 2010 | 12:16 PM
  #870
l67cooled's Avatar
l67cooled
I wonder how well the detroit true track LSD would work. Have you herd anything on these? EDITED: I looked up the aussie locker and with no doubt I'll be using the aussie, especially for the money.
Ford 8.8" Detroit True-Trac, 31 Spline
What do you use up front to adjust your camber? Do I need to add something or is there a stock way to adjust it?
