North Dakota Chapter Join Chapter, Leader: hav24wheel
ND Chat and Other Meaniful Posts
Old Mar 31, 2010 | 12:56 PM
  #331
l67cooled's Avatar
l67cooled
Originally Posted by hav24wheel
All my stuff is upgraded a bit, so I like to push more voltage to the plugs. The wheeler runs high rpms and I don't think the stocker would be up to the job of 5000 and up rpms for long. But the 94 gets to run the original Ford unit a bit longer.
Which alt are you running? I'm in the need of converting over to the 3g. Did some wheeling this weekend and my electric fan really worked the battery.
Dave you weren't kidding; the dessert really has some nasty spots this year. I went alone so I didn't even attempt half the holes around there. There was one guy down there that was stuck pretty good, so I'm going to run down there today and see if he got out yet. I tried pulling him out but I couldn't get on dry ground and I was pulling dead weight since his truck died and wouldn't start again. Lost cause with my little truck
Old Mar 31, 2010 | 12:58 PM
  #332
460/5's Avatar
460/5
Zombie Survivalist
stop makin me jealous guys!
Old Mar 31, 2010 | 01:06 PM
  #333
hav24wheel's Avatar
hav24wheel
On my 94, its just the stock alt. But its on its way out, than I'm gettin one off a powerstroke. The wheeler has a 100 amp off a old crown vic, I have a lifetime warranty one on there and it burns it up once a year. That's runnin two Sable fans though. How does your alt bolt on?
I always use to go down there and pull people out. I am in the process of puttin the motor back together for the wheeler, so I'm hopin the weekend before I get hitched I can go wheelin. But just to pull someone out I guess my 94 would be ok. Might get the job done anyways.
Old Mar 31, 2010 | 01:18 PM
  #334
460/5's Avatar
460/5
Zombie Survivalist
man... is there anywhere near me that i can go??
Old Mar 31, 2010 | 01:21 PM
  #335
l67cooled's Avatar
l67cooled
Sorry trey! I'm sure you'll eventually make it out.
My alt is the 2 hole mount top and bottom. How does the power stroke bolt up? What amperage does it put out? I was just planning on hitting Johnsons to look for a 130 amp 3g, hopefully get it for 30 bones or less. Than just rewire it in.
http://fordfuelinjection.com/public/...ternator01.jpg
  #336
hav24wheel's Avatar
hav24wheel
Go "section line runnin". But be warned, some farmers will get mad at u.
Old Mar 31, 2010 | 01:24 PM
  #337
460/5's Avatar
460/5
Zombie Survivalist
lol. i think ill hold off on bein where im not sposed to be till i get somethin other than my bald tires...
  #338
hav24wheel's Avatar
hav24wheel
See, my 94 bolts on with 3 bolts, so that's why I can run the power stroke alt. So, ur going to have to stick with one off a mustang/Sable or the like.
Old Mar 31, 2010 | 01:25 PM
  #339
l67cooled's Avatar
l67cooled
How much you asking for your f 250?
Old Mar 31, 2010 | 01:27 PM
  #340
l67cooled's Avatar
l67cooled
Gotcha. I was kinda thinking your 94 was the newer style bracket.
Old Mar 31, 2010 | 01:28 PM
  #341
hav24wheel's Avatar
hav24wheel
Its not against the law to be on section lines, its just some farmers get mad if u rut them up because they drive on them to check fields/cows and whatnot
Old Mar 31, 2010 | 01:31 PM
  #342
460/5's Avatar
460/5
Zombie Survivalist
you askin me?? im wantin bout 3500, obo...
Old Mar 31, 2010 | 01:32 PM
  #343
hav24wheel's Avatar
hav24wheel
yep, that's how the 94 is. I've been meanin to get a 3G alt for the wheeler, but I need somettin with a warrenty, because seems like I always burn them up on the wheeler.
Old Mar 31, 2010 | 01:34 PM
  #344
460/5's Avatar
460/5
Zombie Survivalist
how are you burnin them up all the time??
Old Mar 31, 2010 | 01:39 PM
  #345
l67cooled's Avatar
l67cooled
Yeah trey I was asking you. Thanks! I'll let you know if I find someone looking.
Dave do you wash them out after wheeling? I've herd that helps a ton. A warranty is nice I guess but at 140 a pop I'm chancing it with a junk yard pull.
