North Dakota Chapter Join Chapter, Leader: hav24wheel
ND Chat and Other Meaniful Posts
Old Apr 5, 2010 | 10:29 AM
  #451
l67cooled's Avatar
l67cooled
Originally Posted by 460/5
man. you guys find some BIG holes to get buried in!
Yeah I'm not very good at estimating how deep water covered holes are, which is why I'm now pretty freaked by them. The time I was referring to I actually fell into a small channel about 2 feet from the main river channel, so it could have been much worse. As soon as I entered the water, I dropped in up to my headlight, by the time I got out my front end was submerged over the hood. I think the cleaning is what keeps me from hitting water holes anymore.
Old Apr 5, 2010 | 10:47 AM
  #452
hav24wheel's Avatar
hav24wheel
If I'm unsure of how deep water is, I go into it backwards. That way the motor is dry it u plop into a big hole.
Its crazy how soft the ground is along the river though. That's usually the part that gets you stuck good. Its "suction" keeps you from gettin out.
Old Apr 5, 2010 | 10:58 AM
  #453
l67cooled's Avatar
l67cooled
^^ Very true!
Hey Dave, I noticed you have your rear diff welded. Would it be unwise for me to weld up my 8.8 rear? ( I think thats what I have ) Its not a dd but I do drive it on the street quite a bit.
Old Apr 5, 2010 | 11:03 AM
  #454
hav24wheel's Avatar
hav24wheel
Bad idea if u use it on the street too much. When I had a welded rear in my 79,(drove it to wheelin spots) I broke a lot of rear end parts, and that was a 9 inch. If you see any street time, I hate to say it, but a locker is the way to go. I've been lookin. Fo one for my 8.8 in my DD.
Old Apr 5, 2010 | 11:28 AM
  #455
460/5's Avatar
460/5
Zombie Survivalist
you broke 9" parts on the highway?? how??
Old Apr 5, 2010 | 11:29 AM
  #456
l67cooled's Avatar
l67cooled
well that's good to know. I kinda figured it wouldn't work well. How much can you pick up a locker for?
Old Apr 5, 2010 | 11:36 AM
  #457
hav24wheel's Avatar
hav24wheel
Around $250 for a Lockright or a Aussie locker. Maybe $500 for a Detroit. I'm goin to try a Aussie in my DD, and if that doent hold up, put a Detroit in it.
I am hard on stuff, in my old 78( oops I hit the 9 earlier) I broke a rear axle shaft makin a u turn in the street. I blew the carrier bearing caps off the third member pullin onto main. I busted a spool in half on the interstate. I broke a cross pin (had a mini spool) tryin to pull out a stuck pickup. Did I mention I'm hard on stuff
Old Apr 5, 2010 | 11:40 AM
  #458
460/5's Avatar
460/5
Zombie Survivalist
lmao! so what youre sayin, is that someone who is less prone to breakin stuff could get away with a lincoln locker?
Old Apr 5, 2010 | 11:45 AM
  #459
hav24wheel's Avatar
hav24wheel
No, not really, a welded rear has their place, and its not on the pavement. Maybe if it was a 10.25 instead of a 8.8. But still, lockers are a lot better for use on the pavement.
Old Apr 5, 2010 | 11:50 AM
  #460
460/5's Avatar
460/5
Zombie Survivalist
umm... i drive a 250... just to make that clear... lol.
Old Apr 5, 2010 | 11:54 AM
  #461
hav24wheel's Avatar
hav24wheel
Yes, you do, but the origoinal question was about a 8.8. Now for yours, is it a Full floater 10.25 or not? Either way, with the experiance I've had with welded rear axles on the street(of all sizes and makes) I would still go with a locker.
Old Apr 5, 2010 | 12:17 PM
  #462
l67cooled's Avatar
l67cooled
Well for 250 I don't know why anyone would want to weld the rear. I think I'll keep looking for a f250 donor truck, then I'll add a locker. Trying to build it up as cheap as I can.
Old Apr 5, 2010 | 12:20 PM
  #463
hav24wheel's Avatar
hav24wheel
You can find 10.25s for as little as $100. So that part is easy. Than most of them should bolt into the 150 easy
Old Apr 5, 2010 | 12:24 PM
  #464
l67cooled's Avatar
l67cooled
Dang!! Do you know if ones for sale around here? I have yet to check johnsons, but I'm sure they will want a pretty penny for anything like that.
I'm also looking for a front strait axle, so if you know of one let me know.
Old Apr 5, 2010 | 12:26 PM
  #465
hav24wheel's Avatar
hav24wheel
I'll do some lookin. You want a D60 for the front or is aD44 ok?
