Sponsored by: Real Truck
4R100 life span?
Old May 27, 2009 | 10:26 PM
  #46
big poppa's Avatar
big poppa
I bought my early 03 new and I babied it thruout the years except for the occasional romps to blow it out and I got 119,200 on it now. Just a couple months ago I upgraded to a John Wood VB and the shifts are crisp and right on, one of the best investments I made for my trans, hope it goes another 119,200..
Old May 28, 2009 | 02:07 AM
  #47
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by Krewat
Mark Kovalsky has said numerous times it was only the diesels that had the bad diode, but ... I distinctly remember it wasn't diesel-specific. Dunno... I'm waiting for mine to go
That's what we were told when I worked in Automatic Transmission Engineering at Ford. I didn't work on the 4R100, but I knew many people that did. The story that we were all told was that all the gas engine trucks had the diode replaced before sale. Apparently a few slipped through.
Originally Posted by bill11012
does the 6.0 have bigger cooler than a 6.8 or 7.3?
Yes it does. The 6.0L cooler is MUCH larger than either the 6.8L or 7.3L coolers.
Old May 28, 2009 | 07:45 AM
  #48
bubbasz1's Avatar
bubbasz1
Originally Posted by miller_feed
Like Art said, no gasers were sold with the Diode, they changed them all out before they started selling the trucks. From what I read from Mark. I also wonder about your and your son having the Diode in his trans.
I was on another forum, wish I could find it again, that had a local engineer posting on it.(by local I mean assembly plant engineer from the truck plant) and basically they were using diode transmissions in anything they needed them for until the fix came through. I will try to find the forum again, it was interesting.
Old May 28, 2009 | 08:37 AM
  #49
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Originally Posted by Greg B
Don't know about the 6.8, but the 6.0L cooler is bigger than the 7.3L.
Believe it or not, the V10 trans cooler is surprisingly bigger than the 7.3 trans cooler. I ran that for a little while before I was able to afford a 6.0 trans cooler. But there is no comparison between 6.0 trans cooler and V10 cooler; the 6.0 trans cooler is MUCH more superior.
Old May 28, 2009 | 10:21 AM
  #50
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
That would be interesting reading if you find it, thanks. I guess you read Marks post. Thats strange.
Old May 28, 2009 | 12:26 PM
  #51
madjak's Avatar
madjak
Mine went out at 80,000, almost on the money.
Rebuild is guaranteed for 12 months or 12000 miles. Hope it last a lot longer than that.
Old May 31, 2009 | 10:52 AM
  #52
Fastbird's Avatar
Fastbird
Mine went out at 103,000
Old Jun 1, 2009 | 01:33 PM
  #53
bill11012's Avatar
bill11012
Modular motor junkie
so how much better is the newer torque shift?
Old Jun 1, 2009 | 02:01 PM
  #54
Toreador_Diesel
Virtually indestructable....
Look down in the 6.0 and 6.4 forums and see how many trans failures you read about. From what I've read it can handle up to 1100 ft/lbs of torque
Old Jun 1, 2009 | 02:22 PM
  #55
jk080's Avatar
jk080
Transmission Rebuilder
Not to knock the Torque Shift, but mine has failed twice, once at 12k (dealer fixed) once at 55k (I fixed). Both times the diode in the coast clutch drum let go.
I must admit the only Torque Shift that has come through my shop was my own
I think they are good transmissions.
Old Jun 1, 2009 | 02:25 PM
  #56
bill11012's Avatar
bill11012
can i swap from 4R100 to a torque shift?
Old Jun 1, 2009 | 03:30 PM
  #57
Toreador_Diesel
Welcome to the club, it's not possible at the current time.
If I could be done, myself and other 7.3 owners with failed trannies would have done it.
Old Jun 1, 2009 | 03:45 PM
  #58
krewat's Avatar
krewat
Someone once posted about a TorqShift stand-alone controller they found somewhere on the web. Of course, I didn't keep a link.
Old Jun 1, 2009 | 04:02 PM
  #59
Toreador_Diesel
Neither did I, wish I could find it though....
Old Jun 1, 2009 | 04:11 PM
  #60
bill11012's Avatar
bill11012
why not?
